Go to Post sign up to be an organ donor, and encourage your friends to be organ donors. - dtengineering [more]
Unread 30-01-2003, 18:48
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
pneumatic system pressure
view me as a pneumatic idiot..... in somewhat stupid terms, explain to me how you get a stored 120 if the system is at 60 psi??
also, why is the relief valve on the pressure (which says it releases at 120 psi) tripping at around 60-70 psi? is it just defective? or am i missing something obvious?
sorry if this has been answered, but what i can understand doesn't talk about this
Trust, Love, and Magic
Unread 30-01-2003, 18:52
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Me being a programmer and all should probaly not answer but here goes.
The Pump will be directly connected to the tanks giving you as much pressure as want up to 120 psi. Then before the air can be used it must go through a regulator which will regulate it to a max of 60 psi. As for the relief valve on the pump I am not sure why yours is not allowing the full pressure.
Unread 30-01-2003, 18:58
make me care
#0555
Team Role: Student
the rules say something or other about the regulator having to be the first thing in the series (compressor-regulator-tanks, not the other way around).
Unread 30-01-2003, 19:11
rust710's Avatar
Regulator Maxes out at 60 psi so if it is before it the it will not get to 120 psi. I think the rules say that the order is pump-tank-regulator-system.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 30-01-2003, 22:46
Please read page 4 of the pneumatics manual and rule M11.
Unread 30-01-2003, 23:35
make me care
#0555
Team Role: Student
thx for the tip, next time my team asks me to look on the forums for something, i'll make sure they READ first
god $@#$@#$@#$@# pneumatics book, making me go online, why i oughta...
Unread 31-01-2003, 00:46
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Here's an example of what your pneumatics could look like. This is the FIRST 2003 Demonstration Board:
The best moments of our lives fall in two categories: those that did happen and those that did not.
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
