Go to Post Bring 'em on, kiddies. You underestimate the power of Amanda Morrison. - Amanda Morrison [more]
Unread 30-01-2003, 19:15
T967's Avatar
T967 T967 is offline
5 IA teams, WHOs w/me?
AKA: Seth F.
Team Role: Student
T967 is on a distinguished road
Send a message via AIM to T967
Skid marks
Has any team expirianced penalization for skiding? If so how big was the tire skid? Was it dark? What kind of tire did you Have?
Old dude wondering if he can really get back into this crazy thing called FIRST.
Unread 30-01-2003, 19:28
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
If the skid marks are rubber, then that's a good thing, because that means your wheels are being damaged and not the carpet fibers. You shouldn't be penalized for this.
If they are furry, that means the carpet fibers are being ripped, which is a big no-no.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 30-01-2003, 19:57
SouthBronx SouthBronx is offline
#0380 (G-FoRcE)
SouthBronx is an unknown quantity at this point
Send a message via AIM to SouthBronx
they r really strict when it comes to carpet so make sure you don't tear it
Unread 30-01-2003, 21:06
BillyGoats BillyGoats is offline
Paper Eater
None #0061 (Intimidators)
BillyGoats can only hope to improve
Send a message via AIM to BillyGoats
Thumbs up
um, we ripped the carpet last year, i dont think they get mad. Well they where mad becuase they had to fix it but you know
Unread 30-01-2003, 22:01
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
Just make sure you don't grind up the carpet every time you turn and i think you'll be ok...
if it happens in a pushing match or something i'm sure they'll understand
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 30-01-2003, 22:17
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
They are situationally strict. If a device of your's is poorly designed (i.e. Metal Arm Hit's Floor) and causes carpet damage from normal forces, you will be penalized. If say, you get tipped over, slide down the ramp and the top of your bot smacks the carpet causing a tear, i doubt you would be penalized, and neither would be who tipped you.
If the damage is YOUR FAULT, via design, you will be penalized when damaging carpet. Test your bot in as many situations as you can (without breaking it) to see if you could possibly damage carpet. If you have the weight to spare, I'd suggest line all metal components that could feasibly hit the ground with a soft rubbery material. If that piece hit's the ground, having a small shock absorber will both help prevent damage and also help prevent breaking a component.
Unread 30-01-2003, 23:27
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
PIeces of metal shouldn't be close to hitting the ground anyways, as you need almost a 2" clearance to make it over the ramp.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 30-01-2003, 23:48
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
there already was a thread about this... i'm sure of it....
the refs don't mind tears and skids as long as its a one time thing. if your robot keeps tearing because of a design flaw (especially if it isn't) and you don't try to fix it, then the fur (or metal) will fly
Trust, Love, and Magic
Unread 31-01-2003, 02:54
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Last year we transferred weight and got into plenty of pushing matches. In two of those matches there was so much pushing the rubber of the treads came off, leaving long "skid" marks. We were never penalized though.
And no we didn't damage the carpet. We just had to replace our treads.
Unread 31-01-2003, 06:38
Gadget470's Avatar
A Fire Outside
That's partially what I mean. having too small of a clearence wouldn't be a DQ'able design flaw until you rip the carpet. Even if you have the clearence, your center of gravity may be off, when taking off you may tip back and jam up on a metal piece.
Adding soft-ish material to hard material is also a saftey factor. 2 years ago (on 247) one of the mentors almost lost his eye. Would have if he didn't have saftey glasses on. But if that arm hit 2 inches lower he would have gouged his cheek. As a precaution, whenever possible, put some form of padding on moving objects.
Unread 31-01-2003, 07:24
Remember that the rules this year for allowable traction devices and allowable field damage have changed significantly since last year. For this reason, any ruling that the refs made in the past about skid marks is not valid for this year.
If your wheels make skid marks in practice, they will make them 10 times worse in competition, and so you should probably not use them.
