Go to Post I'd love to see a simple, robust system that connects quickly and dependably. - Andy Baker [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 27-04-2013, 07:53
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
OPR vs Record at championship
One item that is amazing to me thus far is the discrepancy of OPR vs the record of the teams. At Michigan State Championship, it was a shoot out for most matches and OPR matched your ranking fairly well. So far from what I've seen, not so much so at St. Louis. But then again I am not there.
I can think of two reasons:
1) With 100 teams per division the field is not as deep as Michigan.
2) There are only 8 matches per team so the match difficulty is not equal. Or there is a lot left to the "luck of the draw"
So my questions are:
1) do you agree with these observations?
2) is it that way every year because the issues are inherent to the way the system is set up?
3) Am I biased because I am in Michigan?
Unread 27-04-2013, 08:02
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: OPR vs Record at championship
8 matches to sort 100 teams is a much coarser function than 12 matches drying 64.
Unread 27-04-2013, 11:16
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Well, several teams have stepped up their game since their last regional, so sometimes it's not "technically" a discrepancy, just problems getting fixed.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 27-04-2013, 11:31
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
How well does one metric poor at evaluating robot performance correlate to another metric poor at evaluating robot performance?
Unread 27-04-2013, 12:33
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Poorly?
Unread 27-04-2013, 13:02
Ivan Malik's Avatar
Ivan Malik Ivan Malik is offline
Any other Anthropologists out there
Ivan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant future
I forgot just how bad 8 matches is at sorting... add in the 40ish extra teams and its even worse... Smaller divisions are a must in the future.
For those who are way better at statistics than I am, would doubling the number of divisions, but halving the teams in each division result in better sorting? Same number of matches (more would be helpful) but a smaller group to sort...
You could keep the same number of fields; heck there could be two "pools" per field and have the winners of the pool elims play each other to determine the field champion. The field champion would then represent the field on Einstein.
FRC Student: 2007-2010 ~ FLL Mentor: 2007-2009, 2012 ~ FIRST Volunteer: 2012-present
Scouting, Chairman's, Mechanical, Business, Community Outreach, anything that doesn't have wires or code, but I dabble.
Unread 27-04-2013, 13:35
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
The qualification ranking used in FRC is pretty poor. Even if you had some very good mathematical evaluation of robot performance (which in certain years, including this year, OPR is), it wouldn't correlate well because the standings are very often not a good evaluation of robot performance.
So really, there's a corollary to Lil Lavery's post:
-A bad performance indicator (OPR in his opinion) doesn't correlate well with another bad performance indicator (standard qual rankings with 8 matches played)
-Also, a good performance indicator (OPR in other's opinions) doesn't correlate well with a bad performance indicator.
Given the definition of OPR: "the average number of points a robot's presence adds to its Alliance's score", the real question about OPR is not whether it predicts final standings, but rather whether it accurately predicts an upcoming match score given the input of matches played before.
Unread 27-04-2013, 13:41
Bongle's Avatar
You could keep the same number of fields; heck there could be two "pools" per field and have the winners of the pools play each other to determine the field champion. The field champion would then represent the field on Einstein.
The answer to this is to consider what would happen if you took it to the extreme: what if you had pools of 6 robots that played 8 matches against each other, and they had a single round playoff of one alliance against another to determine the pool winner, then gradually played against the other pool winners, tournament-style?
The answer: as you reduce the pool size, you reduce the chance of the objectively "best" robot actually winning the entire competition and increase the effect of luck - the best robot might have 4-5 mediocre robots in their pool to pick from, and so can't win the whole thing against an alliance of 3 medium robots from another pool. Put another way: the pool results would be very accurate (the best robot would tend to win all the time), but the overall results would be less accurate since the best robot might not have good robots to take to inter-pool play with it.
The main way to make championships more "accurate" is to play more matches, which really comes down to field-hours: you either need more fields for the same hours, or to simply use the 4 fields you've got for longer hours in the days you've got. Or you need to use Einstein to play more matches.
Unread 27-04-2013, 13:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
IMHO, the 2013 ranking system is the least problematic ranking system ever devised by FIRST. Very straight forward, entirely based upon robot performance, no weirdness from coopertition or losing score.
The only way this system can be improved is with more matches. The more matches a team has, the better the odds are that luck will filter out and skill will filter in.
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-04-2013, 14:24
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Hmmm... this sounds like it could be one of those statistical traps, but I've thought it over a couple of different ways and I can't think of any way that would improve the variability. Not to mention that, even if it did, it would still weaken the eliminations alliances...
When I was in the TBA chat, we talked about what I thought was a really cool idea: Have 6 divisions, with the same number of teams (I think there's room in the dome for 2 more fields, don't you?) That would dramatically increase the number of matches, and make for a more regional-like environment. But what do you do with the 6 division winners at Einstein, you ask? This was the really good idea someone suggested: have a round-robin to decide the 2 alliances for the finals. Yes, it would take more time - 13-15 matches before the Einstein finals, instead of 4-6. But if you cut down on the hour before Einstein and all the speeches, you could almost fit them without expanding the schedule at all... not to mention that, with the smaller divisions, you could start eliminations earlier. Any feedback? I think a round-robin would be really fun...
Does anyone else remember when TBA signatures actually worked?
Unread 27-04-2013, 18:01
shrkeatsman shrkeatsman is offline
AKA: Magee
FRC #2978
shrkeatsman is an unknown quantity at this point
i think that if there is an OPR there should also be a DPR defensive power rating,
because like my team we were all most always playing defense and were put up against teams that we had a hard time playing defense against. So our ranking defiantly didn't show our potential.
Unread 27-04-2013, 19:47
If you want a number for DPR, there already is one. The DPR analogy to OPR is given by the following simple relation:
DPR = OPR - CCWM
But it's not very useful, for reasons discussed elsewhere. [edit]fixed broken link[/edit]
Unread 27-04-2013, 20:37
AKA: Magee
FRC #2978
DPR = OPR - CCWM
thank you but can you translate the ccwm?
thanks
" We lost a bolt? We must re-design the whole thing..."
Unread 28-04-2013, 15:00
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I know your user title has said something to this effect for a while, but I really have to disagree. OPR is never perfect, but I found that it worked pretty well this year. I used it to predict the Saturday seedlings of SVR Friday night with a fair degree of accuracy. It was a pretty good measurement of how much we contributed to our alliances, and we found that it represented other teams' performance fairly well too.
Of course, OPR can't predict exactly how many points you (or anyone else) will score in a given match. But in my experience, it does provide a fairly accurate way of predicting which alliance will win a given match.
Why did champs seeding not correlate well to OPR? Because 8 matches is way too small of a statistical sample.
-Plutarch
Unread 28-04-2013, 15:08
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I can tell you 422 went the opposite of the OPR projection of 2-6 and posted a 6-2 record and everyone will agree that CMP was by far nowhere near as good on the whole as DCR, and the actual robot scores show that.
OPR is becoming less reliable as teams in CMP divisions are coming in with pre-CMP match differences of up to 50.
