Re: 6 CIMs and 4 MiniCIMs - Will they stay?
I don't think AndyMark would have put that much time engineering a 3-CIM gearbox if it were a 1-year thing. Just my thought.
I sure hope so. The fact that the 10 most powerful motors this year had the same mounting and shafts was a blessing.
I hope it stays. We used only 6 motors this year thanks to a PTO gearbox, so I want this rule around next year so I can actually use it.
I talked with the people in AndyMark's sponsor stand about them releasing more 3 motor gearboxes and was told that FIRST had not given them any signs about whether or not 6 CIMs would be staying. It does seem logical that at the least some MiniCIMs will remain, as IFI has made a significant investment into that motor, so 4 CIM 2 MiniCIM drive will most likely remain an option.
I think the motor rules made the game extra interesting. That said, I'm torn. I think so many powerful motors added to the game, though they also made it easier. I really hope we get at least 2 Mini-CIMs and 4 CIMs next year, but beyond that I feel it is a bit excessive(remember we still have 8 more 500 series motors).
Let me just say this: 6-CIM drivetrains can break the main 120 amp breaker if they are stalled. With a 6-CIM drive, you're essentially giving good defenders a way literally shut your robot down.
As for continuing to have insane amounts of power like we did this year? I sure hope it continues, but I certainly wouldn't take this much raw power for granted. It obviously depends on the game, but I'd bet on 4 CIMs and 2 Mini-CIMs for next year. |
#7
So can 2 CIMs, or 4 CIMs. As long as you don't gear too high for the amount of torque you have available (which will increase with the number of CIMs), your drivetrain should stay traction-limited and never stall.
#10
I only see the extra motors staying if the available power increases (bigger battery/main breaker).
#11
This is one of those things that teams need to be aware of and design around, as part of the design challenge. I think it's much more real-world to actually have some imposed design constraints rather than having FIRST provide us a system that can be plugged together and won't fail (like Lego League). Even FTC needs to be careful about motor loads. |
#12
Yes. 766 shut down 971 in this way at a match at SVR, and we won the match because of it. I have also heard anecdotal evidence of 254 having similar problems.
#14
Maybe someone from 971 can answer this, but what gear were they in (and what speed)? Do you have video of the match?
#15
I believe its on TBA. It might have been match 50.
