Go to Post Curse those filthy wrench-swinging rivet-popping screw-driving hammer-smashing mechanical barbarians. Hand over the robot to the programmers! - cjl2625 [more]
View Poll Results: Which codec will your team be submitting with?
Cinepak 3 12.50%
Intel Indeo 2 8.33%
Quicktime 11 45.83%
FORGET AUTODESK, I'm going Divx or something else, Just because I can! 8 33.33%
Voters: 24. You may not vote on this poll
Unread 30-01-2003, 22:48
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Originally posted by reisser
Ok I just spent the time to do an image quality vs. compression test with all of quicktime's supported codecs and DivX. I think we all know the benefits of DivX well so I will leave that out of here. The codec that had the least artifacts, ailiasing, and other unwanted stuff while still having a very manageable file size was, in fact, the video codec. I urge you to try this experiment yourself. You should be pleasantly surprised by its performance. As for audio, I would like to hear some of your expert suggestions on that. Usually I would do PCM due to lack of expertise.
-Brandon
The Video Codec is a very old codec, it was primarily used 5 to 8 years ago. Its kind of obsolete. The best Image Quality to kilobytes/sec ratio is either MPEG-4 or Sorenson 3.
If you see the picture I recently posted up on top, If you click settings, you get another window giving you a bunch of options like quality, fps, etc. If you put those to Max qualities, you will see a much better picture, and also a higher bit rate.
DIVX is ok, not great though. It is a variant of the MPEG-4 Standard that does not comply with the ISMA (Internet Streaming Media Alliance) standard. The only reason DIVX took off, is because of its the #1 format for P2P networks for downloading DVD's.
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
FIRST Blast: 2004 Autodesk Software Information! miketwalker FIRST E-Mail Blast Archive 1 03-11-2003 21:21
Autodesk hath taken pity on us... RachelOfMars 3D Animation and Competition 2 05-04-2003 11:12
