Go to Post I would like to think that I would be considered smart no matter who I was. - Kelly [more]
Unread 30-01-2003, 00:56
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
783's Gearbox
Here are 2 teasers of our gearbox (if you put the 2 pics together, you can basically see all of it - minus the shifter (hi and low speed) because it is not attatched yet.
http://www.chiefdelphi.com/forums/pi...&quiet=verbose
If you want to read the black-board where we did some number crunching (note: several of those numbers have changed):
http://www.chiefdelphi.com/forums/pi...&action=single
And finally, our wheels (all home made....we havn't put the final tread on it yet - we are still testing what works the best)
Put all that together, and it will be 2 sexy gearboxes (one on each side )
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 30-01-2003, 08:23
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
That looks nice!
What are you going to use to shift it?
Unread 30-01-2003, 08:32
Gope Gope is offline
#0016 (Bomb Squad)
Gope is on a distinguished road
Wow. That thing's beefy. I guess you really listened when they said "build to endure."
Kinda bulky, but looks really nice.
College and its wonders. First year and alot of other FIRSTs.
Unread 30-01-2003, 14:57
Harrison's Avatar
Originally posted by Caleb Fulton
That looks nice!
We're using a small pneumatic solenoid (around a 2" stroke).
It will be attatched to the shaft that is furthest away from the chip motor (see the 1st 2 imagesIi posted), and move those gears, and thus the speed that shaft is spinning at (it is our output shaft).
As for being beefy, well, yeah...lol...thats an understatement
It won't ever break, but we are paying for that with weight (altho granted it is spread out a lot).
I'll post more pics once it's all assembled (looking like that will probably be tonight, or tomorrow for sure).
Thx for the comments!
Harrison Ruess
UOIT '08 Alum
Unread 30-01-2003, 15:09
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
They came out sweet!!! Ours look the same! Just the compact version! We did a lot or re engineering to ours! What is your gear ratio and how fast will you be going??
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 30-01-2003, 23:02
Harrison's Avatar
Depends on what gear we're in.
In low gear we go around 1.5fps, in high, its about 9fps (thats why the gears vary in size so much).
I can't recall the exact ratios right now (its been like a 15 hour day today....*falls asleep*).
Harrison Ruess
UOIT '08 Alum
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Connecticut teams, gearbox needed GaelHawks230 General Forum 0 08-03-2003 13:41
drill gearbox schematic? Jeff Sharpe Technical Discussion 3 21-01-2003 00:18
Window motors / F-P gearbox Steve Motors 0 15-01-2003 07:57
