Go to Post Mountain Dew and Taco Bell. Nom Nom Nom. - R.C. [more]
Unread 30-01-2003, 23:05
Kwang Kwang is offline
#0865 (WARP 7)
Kwang is an unknown quantity at this point
Question Yaw Sensor Connector Kit
Hi
Has anyone noticed that the quick connect, (black thing with square holes in it), does not perfectly fit the sensor? It seems one size too small. I could force it in, but I would like to know if there is a "better" way of doing this.
Unread 31-01-2003, 02:10
Micah Brodsky Micah Brodsky is offline
#0824 (SWAT)
Micah Brodsky is an unknown quantity at this point
I think, unfortunatly, this is already the 'better way.' Looks to me like FIRST figured the actual connectors were never gonna make it to us, so they cobbled together something useable, but flakey. Someone previously suggested soldering directly to the sensor contacts, but I dunno...
I suppose you could just always buy a 3rd party yaw rate sensor from DigiKey or something, if you couldn't get any satisfactory results... *shrugs*
--Micah Brodsky
Controls team
Team SWAT 824
Unread 31-01-2003, 21:22
The connections are made to pins which will take the soldering; if last year's model is any indication (We had a blown one).
I soldered to the pins on a different one, which is still working.
Caution: I used a small iron, and was on and off quickly. If your solder cup connections on the DB25's are lumpy, forget soldering to the pins of the gyro !
Haven't got this year's out of the box, yet, just the specs.
Anyone know where to buy a spare yaw rate sensor? Jim Meyer Technical Discussion 11 30-03-2003 21:18
Yaw rate sensor pin-out GregT Electrical 8 18-02-2003 00:07
yaw sensor CHSguard72 Electrical 1 06-02-2003 01:44
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
