Go to Post Aha I just noticed you're from my team. --Petey - Petey [more]
Unread 29-04-2013, 19:52
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Best impromptu fixes of 2013
Our shooter wasn't elevating to the right angle when we were prepping our bot for a bedford district match, so the programming team was called over to address the issue in the queue. I go down there and upon close inspection, i see a piece of metal that our potentiometer for shooter angle feedback was attached to is completely bent inwards. After locating a pair of clamps from our alliance partners and a little elbow grease the angle was back withing a few degrees tolerance.
What's your best impromptu fix?
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 29-04-2013, 19:54
Koko Ed's Avatar
Happy Birthday! Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Best impromptu fixes of 2013
There probably be a giant list of all the ugly pool noodle extensions everybody made to stop FCS robots from destroying them.
Unread 29-04-2013, 19:57
BrianArneson BrianArneson is offline
BrianArneson is an unknown quantity at this point
If I remember correctly, 2169 converted their shooter at a regional to be able to shoot from feeder station and they ended up being really good at it.
7 year FRC participant
Mentor on FIRST Team 662 - 2 years
Former student FIRST Team 4550 - 1 year
Former student FIRST Team 443 - 4 years
Unread 29-04-2013, 20:01
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Friday night we decided we needed to extend to 84 inches or as close as possible and we had less than a pound to do it. The final fix worked beautifully and took 20 minutes from conception to final product. I will post pics or video if any of my team has any.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 29-04-2013, 20:03
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Pool noodles are lame, try a telescoping corrugated plastic sign meant for the stands.
https://www.facebook.com/media/set/?...02921& type=1
http://www.youtube.com/watch?v=Ly62dYKShOM
Unread 29-04-2013, 20:11
610's anti-FCS device for Champs.
Unread 29-04-2013, 20:13
Annemarie433 Annemarie433 is offline
AKA: Annemarie
FRC #0433 (Firebirds)
Annemarie433 will become famous soon enough
I am on pit crew on my team and they went into the quarter finals at a district with a half powered shooter (a short we found much later). The bot was set up for the 2 pt goal and I was up in the stands really sad that our auto wouldnt work, when one of our mentors suggested moving the bot to the 1 pt goal. So I ran down to the field (luckily because of tech-difficulties they were delayed) and told the drive team to move the bot, which gained our alliance 6 pts. After the match was over we stared at the screen until the score 150 to 156 came up and we won by those 6 pts. Pretty Amazing.
Unread 29-04-2013, 20:17
xraymypanda's Avatar
xraymypanda xraymypanda is offline
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
xraymypanda has a spectacular aura aboutxraymypanda has a spectacular aura about
I've been wondering about all those blockers, could one have been made rigid enough to deflect a dull court shot and redirect it into the blocking alliance's goal?
2011: Head Scout
2012: (figure)Head Programmer
2013: Head Programmer, Chief Strategist, Outreach Executive, and Driver
Unread 29-04-2013, 20:18
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
This year we lost a chain to one of our shooter wheels in Quarterfinals 1 match 1 at West Michigan, due to the cotter pin on the half link pin breaking.
Back in the pits we found a spare pin but no cotter pins or steel wire to replace it with. We ended up using the pin wire from a button to make the quick fix in time to make it out for or next match.
I also remember replacing an aluminum drive shaft from a drill transmission with a 3/8" bolt we cut down, in 2004.
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 29-04-2013, 20:23
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
I don't know the story behind this, but our scouts show that team 236 fell off of the very top of the tower in a practice match and were climbing again in the next match 30 minutes later. If anybody knows how they pulled this off, I'd love to hear the story.
Unread 30-04-2013, 10:59
SoMe_DuDe904's Avatar
SoMe_DuDe904 SoMe_DuDe904 is offline
Minnesota Lead Game Announcer
AKA: Nate
FRC #2169 (KING TeC)
SoMe_DuDe904 is a splendid one to beholdSoMe_DuDe904 is a splendid one to beholdSoMe_DuDe904 is a splendid one to beholdSoMe_DuDe904 is a splendid one to beholdSoMe_DuDe904 is a splendid one to beholdSoMe_DuDe904 is a splendid one to behold
Incorrect, 2169 always could shoot from the feeder station.
See their release video for confirmation.
http://www.youtube.com/watch?v=TT5_RJLG5LQ
After the retooling they saw in Duluth (northern lights) they decided to hide their talents in the Colorado regional, which seemed to work in their favor.
Nate
Lake Superior / North Star / MSHSL - Lead Game Announcer
GO-FIRST - Alumni
KING-TeC - 2169
Unread 30-04-2013, 11:38
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
Yeah, no, I remember seeing 2169's reveal video, and they were already shooting from the feeder station, they could do it since the beginning when they went to the Northern Lights Regional.
Unread 30-04-2013, 15:10
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Problem: No time to take robot apart to get a drill bit in to fix misaligned match-drilled holes?
Soution: Vise Grip. For added safety, we zip tied the vise grip to the robot. The sheet metal didn't budge at all.
Unread 30-04-2013, 15:13
Oblarg Oblarg is offline
AKA: Eli Barnett
We were having problems with two frisbees exiting our shooter at once. Fixed it with a small piece of scrap plastic and some duct-tape to ensure that the bottom frisbee nested a bit forward of the rest in the stack. Problem never came back.
Duct-tape in general played a pretty critical role in our robot this year.
"The breakfast of champions!"
Unread 30-04-2013, 15:21
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
A rookie team we mentored had a welded aluminum frame for the "superstructure" of their robot. While visiting them at the Mt. Olive District, the corners of this frame were covered with duct tape. Somehow, the welds broke(I don't know anything really about welding, so I have no idea if this is the proper term), so their solution was to keep the main frame of their robot together with ducttape
