Go to Post It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder. - petek [more]
Unread 31-01-2003, 07:26
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
your question could have been solved with a little basic trigonometry. Our team did the calulations..based on the height of the rmap and position of the driver station. If you are at least 5' 6" then you can barely see down the ramp. If you are 5' 7" you cansee everything on the otherside of the field. That's it. 5 foot 7 and you can see everything, without a ladder.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 01-02-2003, 14:05
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
i guesse i should write that down on my driver application this year...hehe being 6'4'' will have some major advantages!
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 01-02-2003, 15:47
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
You are negating a few things. Such as if your bot is in the far center starting point, you can't see it (if it's under 2' tall) and that bins will reach a height of 8'2" when placed on the ramp
Unread 03-02-2003, 07:57
Soukup's Avatar
Animation Guru
AKA: David Soukup
sorry...i did forget about bins but...if you think about it..only for the first 15 seconds..will that be a problem. Almost immediatly ...someone will knock the boxes over and you'll be able to see. If not..i guess that's your problem..and you have to work out the problem another way. But if the position of you robot is what you want to see..use a flag. And remeber that you can always see off to the side of the ramp..without any difficulty.
Team 74 Alumni
Unread 03-02-2003, 14:11
skrussel skrussel is offline
no team (000)
skrussel has a spectacular aura aboutskrussel has a spectacular aura aboutskrussel has a spectacular aura about
Hey Ianworld........
I don't think you get to correct people's spelling, when you can't spell 'separately' correctly!!
Unread 06-02-2003, 19:52
Kojib Kojib is offline
#0016 (Baxter Bomb Squad)
Kojib is an unknown quantity at this point
Send a message via ICQ to Kojib Send a message via AIM to Kojib Send a message via Yahoo to Kojib
Hey, Garrett from # 16, the Baxter Bomb Squad. A few years ago, we competed in BEST, a scaled down version of FIRST. In that year's game, visibility was a huge issue. From what I remember at the tournaments, the best thing a team can do to counteract the reduced visibility (other than tall drivers) is to mount a flag on the robot using a flexible pole with lots of memory...if weight isn't an issue, I would recommend using more than one flag, for example one on each corner, the front/back corners, or on diagonal opposite corners. Just my opinion.
Unread 06-02-2003, 20:28
round dice round dice is offline
None #0782
round dice is an unknown quantity at this point
We've managed to simulate some games in our mock field with the sufficient amount of boxes, and visibility/maneuverability of the robot was a major problem. The sides of the boxes did offer some space to ascertain about where the robot was located, but nothing about its orientation.
Also keep in mind how high the boxes are. We rigged up a flag for one of the matches but it was still obscured by the center stacks.
Nevertheless, I'm confident that for the majority of matches the center stack will be knocked down within the first 20 seconds.
Unread 06-02-2003, 21:44
Shawn60 Shawn60 is offline
#0060 (Bionic Bulldogs)
Shawn60 will become famous soon enough
quote:
Originally posted by Ianworld
The robots are pretty big...
From JVN
"Exactly, now try to see THROUGH the giant unfolding wall that is designed to knock down all the boxes, and then guard the ramp.
See the problem?
That's why we're testing our drivers for ESP, while it hasn't been important in the past, we feel it will play an increased role in this years game."
If the robot is 5 feet tall the total height will be 7 feet. How do you see through that?
Unread 06-02-2003, 22:20
John Bono's Avatar
John Bono John Bono is offline
#0990 (We don't have one :cries:)
John Bono is an unknown quantity at this point
I wonder--are there any rules againss bringing a short ladder to the arena. My personal thought on this is to put my friend who is 6' and only 125lbs. on my or someone else's shoulders. It's ingenious--I don't see how they would've thought for that.
"Proof is King. Logic is Prime Minister." -Force-Attuned Krokoth
"Any fool can make things bigger, more complex, and more violent. It takes a touch of genius--and a lot of courage--to move in the opposite direction." -Albert Einstein
"Never put off until tomorrow what you can do the day after tomorrow." -Samuel Clemens
Unread 06-02-2003, 23:13
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
there are rules against that. They were made it last year to prevent people from getting an edge while shooting the soccer balls. You know someone must have thought of it since they made a rule against it. Another wierd rule is to not use snow to cool off motors or bateries. You can thank the canadiens for that one. hehe j/k
Like Aquidneck Island Robotics on Facebook!
Unread 06-02-2003, 23:33
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
makes you wonder why first is so against using vid cams on the robot
Unread 06-02-2003, 23:46
John Bono's Avatar
So, is there STILL a rule against the shoulders thing, cause that'd be kinda fun anyway--I don't care how goofy I'd look. And, also, BTW, those numbers for height are eye level, remember. SO you really should be looking at an all 6' teem.
Unread 06-02-2003, 23:53
Rick's Avatar
Ready to STRIKE!
AKA: Rick Blight
its still there this year. thats considered unsafe anyways. poeple are worried about tripping while walking 3 feet to the controls...........imagine the safety field day the uber safe would have with that.
Unread 07-02-2003, 06:39
SouthBronx SouthBronx is offline
#0380 (G-FoRcE)
SouthBronx is an unknown quantity at this point
Send a message via AIM to SouthBronx
i love the idea of the 4 flags... maybe different color flags, 2 in the back and 2 in the front so the driver in case of visibility problemas, can c if his baby is facing a certain way......
Unread 07-02-2003, 07:30
Soukup's Avatar
Animation Guru
AKA: David Soukup
Originally posted by Shawn60
you dont....you drive right through it....hehehehe
Team 74 Alumni
Who is the most SKILLED driver in FIRST? Austin General Forum 40 05-06-2003 12:33
Middle School Drivers ram General Forum 40 26-02-2003 17:01
A good driver makes his own strategy. What do you think? archiver 2001 26 24-06-2002 02:21
Web Jeep Driver archiver 2001 1 24-06-2002 00:32
visibility Tyler Olds 3D Animation and Competition 0 12-03-2002 16:14
