Go to Post I may be right or wrong but I’ll be happily senile doing it. - ebarker [more]
Unread 01-05-2013, 08:35
bumblebee3339's Avatar
bumblebee3339 bumblebee3339 is offline
Team's main account
FRC #3339 (BumbleBee)
bumblebee3339 is an unknown quantity at this point
Exclamation Best way to improve my coding skills for next year?
What is the best way to improve my coding skills in LabVIEW for the next season?
I want to learn how to have more control on my robot,
do more complex things in autonomous mode,
and learn how to do things with the vision processing.
Please advice me about websites to learn from or things I should focus on.
Thank you!
Unread 01-05-2013, 15:38
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Best way to improve my coding skills for next year?
http://team358.org/files/programming...2009-/LabVIEW/ has a lot of code snippets for any function of the robot.
https://decibel.ni.com/content/community/first/frc has tutorials from National Instruments themselves. A good place to look
Unread 01-05-2013, 16:21
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
I would say the most important thing is to get the simulation tools working. Once you have that, you can then begin to develop and test your ideas without needing a real robot. That is great for two big reasons: 1) you can develop and test your code from the comfort of your home, and 2) you don't have to worry about breaking something if you make a mistake.
After you get the simulation running, there are a lot of ideas on chiefdelphi if you search. Here are a few things to try:
- Shooter speed control: bang-bang vs. PID
- Arm control: use an encoder or potentiometer with a PID controller to control an arm to pre-set posititions.
- Autonomous: use wheel encoders and a gyro to keep track of distance and heading. Use PID to keep your robot driving straight and to drive a set distance.
- Autonomous: control your autonomous routines through some sort of script
Unread 01-05-2013, 21:36
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
One thing that i have always found important when looking at code is that you understand:
-how it works
-why it works
-when it doesn't work
-what is happening behind the scenes
It is important to not only understand that the code or function does something but you should understand to a certain degree why and how it does it.
For working at home away from the robot you can also use labview with an arduino and develop good coding habits and begin advancing your knowledge of control structures
Also don't be afraid to break off and learn Anouther language as learning how to do something in many different ways will help you understand the logic
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 02-05-2013, 11:38
Team's main account
Great idea
what is bang-bang?
and how does the algorithm of driving straight with PID works?
Thx for the help
Is there a thread with all of these ideas in one place?
Unread 02-05-2013, 13:36
Originally Posted by bumblebee3339 View Post
Great idea
what is bang-bang?
Thx for the help
No, they're not in one place - you'll need to search.
Here's a thread on bang-bang vs. PID for shooter speed control: http://www.chiefdelphi.com/forums/sh...highlight=bang
Unread 03-05-2013, 12:41
Team's main account
Thx.
What about the driving straight with PID? How does it work?
Unread 03-05-2013, 12:47
Jared Russell's Avatar
Taking a year (mostly) off
Thx.
Your gyro tells you what your heading is. When you start driving straight, remember what the heading is. As you drive, if your heading drifts clockwise, steer a little bit counter-clockwise. And visa versa.
You could also use the difference between left and right encoder counts to figure out what direction you are driving, but the gyro has the nice property of not caring whether or not your wheels are slipping.
Unread 05-05-2013, 19:39
bulbajackel's Avatar
bulbajackel bulbajackel is offline
Programmin fo dayz
AKA: Chuck
FRC #2408 (Shrapnel Sergeants)
bulbajackel is an unknown quantity at this point
-how it works
-why it works
I second this, knowing why your programming behave the reason it does can help identify what you need to do to do anything you want your robot to do. I also suggest just looking at the object pallet as a whole to see what you can work with. Also do some experiments with the blocks, most are self explanatory, but once you get used to using them, they can take you far!
"It's the programmer's fault"
