Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Unread 01-05-2013, 15:23
apb2390's Avatar
apb2390 apb2390 is offline
AKA: Andrew
FRC #1684 (Chimeras)
apb2390 is an unknown quantity at this point
Re: Innovative Controls
Team 1504, The Desperate Penguins, won two Innovation in Control Awards this year (at the Kettering and Grand Blanc District Events) for their "Space Drive" control scheme. I don't remember the specifics, but it had a whole bunch of cool features, including robot orientation-independent movement.
FRC 1684 (2012-2015)
2012: Programming
2013: Electrical
2014: Design / Electrical
2015: Design Lead / Electrical
4 Years, one Blue Banner. We did it.
Unread 01-05-2013, 19:49
Nick1146 Nick1146 is offline
FRC #1111 (Power Hawks)
Nick1146 is an unknown quantity at this point
Originally Posted by Grim Tuesday View Post
Everyone should see 1111's control board this year; it's a 3D printed model of their robot and controls the real one like a voodoo doll.
Thanks for the compliment. Me and my controls captain built it. We designed to to be a voodoo doll as you said. The voodoo doll controls the mechanism portion of the robot IE the shooter arm and everything attached to it. Pictures of the voodoo doll are attached below.
https://docs.google.com/file/d/0B6AB...it?usp=sharing
Unread 01-05-2013, 20:06
rcepierpont rcepierpont is offline
FRC #1111
rcepierpont is an unknown quantity at this point
I'm the Controls sub team Captain for 1111 Powerhawks, and yes; our controls board does act like a voodoo doll. We call it "Voodoo bot", or machinula: little bot in Latin. The base and aesthetic wheels are ABS plastic printed in a 3-D printer. The structural parts are made of leftover bits of black 80-20, and miscellaneous scrap and FTC metal. Also, plexiglas (or equivalent) makes up the switchboard on the base, and the handle for the shooter arm controller is a piece of PVC.
The arm is on an axle that turns sprockets on a chain that are hooked up to a 16-bit rotary switch, to control the up and down movement of the robot's shooter assembly. There are "firing buttons" at the handle end of the controller to index frisbees into the shooter, and any other switches (shooter on/off, shooter speed, autonomous selector, frisbee indexer de-jamb, arm position indicators, and any other operator control.)
The innards house the wiring, cypress unit, battery for back lights (bright blue LEDs to light up switchboard) and any other breakaway mini-boards for any of the controls. The Voodoo bot works directly with the laptop and what it does, the robot mirrors. Real Steel style.
Unread 01-05-2013, 20:34
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
We used a series of potentiometers in 2011 to mimic our arm. Not very practical in a match, but it made programming arm positions easy. We won an award for it and also our control board.
Here is a picture.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 01-05-2013, 20:47
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
This year we implemented point-click, fully automatic, and manual targeting into our pan+tilt shooter. We also used encoder based (p-loop) drivetrain brakes, and an rpm-based rapid fire mode for our shooter.
FRC Team 987 - It's not enough
Unread 01-05-2013, 20:58
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
I don't know if I have the team correct, but 2349 Hurriquake used a tablet to control their bot and act as the drivers' station. The won innovation in control at the Boston Regional this year. Hopefully someone on their team sees this and either corrects me or expands on this.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 02-05-2013, 10:08
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
These are all really cool methods of control! Really great stuff guys! Keep it coming, and get as technical as you want!
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 09-05-2013, 22:25
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
We're (I'm) working on a custom dashboard in which you draw a path on a scale field and have the robot traverse it. It's sort of like the recording/replaying autonomous, for which I have code, in case someone wants to improve it. It's C++, and horribly written (by me :P ).
Unread 09-05-2013, 22:47
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Originally Posted by Abhishek R View Post
Not sure if it counts, but 1477's driver told me at one of our regionals that he has been messing around with R/C cars forever, and likewise, has a controller to match. They are definitely one of the most agile bots I've seen, so I guess it works quite well.
It looks a bit like this: http://www.getprice.com.au/images/up...572/dc1500.jpg
I cannot overstate this enough: if you have a skid-steering robot and have not tried using one of these controllers yet, then you are putting a large handicap on the learning curve of your driver.
One of the better control approaches we've used for such a drivetrain is having the steering wheel position set a target setpoint for the rate of rotation of the drivetrain, so if you turn the wheel a given amount the robot will try to turn at X degrees/second (using gyro feedback). This has the nice advantage of eliminating rotation overshoot, since as soon as you let go of the wheel the robot tries to stop spinning by itself.
