| Thread Tools |
Rating:
Display Modes |
Things you only do ONCE!
I was just thinking about this while writing in another thread. This may prove to be just a thread to make people chuckle but it also may serve to remind teams about safety and best practices. So here goes a start for the list...
1. Touch a soldering iron to see if it turned on. 2. Carry a battery with one hand, and dropping it. (on your foot or on the ground) 3. Put the red wire on the black battery terminal. 4. Wire the radio to a normal 12 volt output on the PD. 5. Use a crescent wrench as a hammer. (power on or off, you choose.) 6. Hold a robot part in your hand while drilling. ( a variety of errors jump to mind) 7. Put a practice battery on the robot. (actually happens more than you know) 8. Build to last year's dimensions because "they never change". 9. Use a dremmel tool to grind right next to your custom 3D printed part. 10. Mount your bumpers upside down. (except teams 11, 111, 1111) |
Re: Things you only do ONCE!
11. Solder without safety glasses.
12. Use a hand drill with long unbound hair. |
13. Leave male ends of PWM cables exposed.
Design the robot with Mechanum wheels.
15: Leave a wrench on the draw bar on the Bridgeport and turn it on
16: Touch a freshly welded part 17: Touch a rough edge on carbon fiber Last edited by theawesome1730 : 02-05-2013 at 17:58. Reason: number accuracy |
#7
Do the trig for your autonomous mode during opening ceremonies and run the code untested in your first match.
#8
18. Drill something without covering the electronics.
19. Put a popped of chain back on without cutting the power. 20. Spray paint a part outside in 20 degree weather. 21. stand in front of the robot while testing the shooter. |
#9
19. Stick your fingers into one of the big muffin fans accidentally.
20. Stand in front of a robot wearing a green shirt when the robot vision is set to look for a green target 21. Do a poor job tying down your fastener containers in your trailer on the way to IRI. 22. Put your finger on top of a piece of metal in front of the blade while cutting with a bandsaw. 23. Try to hold a piece of metal square into the sanding disk on a table sander 24. Forget to take the chuck out of a drill press with a plate-glass window behind it. 25. Grab a constant force spring and yank it off its top roller. |
#10
Leave the key in the lathe chuck. Whatever you do don't do this.
#11
26. Push a team into the pyramid when they are lining up to climb.
#12
Although it is funny to watch people jump after doing this when reaching in the robot.
#13
24. Leave a chuck key in a lathe and turn it on.
25. Put 3 bolts between the sprocket and a Performance wheel, even though there is a very good reason why there are 6 holes. 26. Use a double sided intake for a ball game. 27. A week 1 regional. |
#14
Team 1684, The Chimeras, did this last year and it greatly increased our versatility. We were constantly happy to have it.
#15
28. Test your robot not on blocks when you have a "joystick" with a Y axis that's stuck at -1.
29. Leave your hand on a pinch point while someone's testing the robot. (Sorry Josh) 30. Spray paint an entire crate on a just cleaned concrete floor. Without newspaper. 31. Stand directly behind a spinning shooter wheel with a "temporary" tread on it. 32. Cut off zip ties with a knife with the blade up. |
