Go to Post I understand that Dean Kaymen has now invented a super "sniffer" that can scout-out anyone within hearing distance that is remotely-involved with FIRST. - dhitchco [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 02-05-2013, 17:48
Things you only do ONCE!
I was just thinking about this while writing in another thread. This may prove to be just a thread to make people chuckle but it also may serve to remind teams about safety and best practices. So here goes a start for the list...
1. Touch a soldering iron to see if it turned on.
2. Carry a battery with one hand, and dropping it. (on your foot or on the ground)
3. Put the red wire on the black battery terminal.
4. Wire the radio to a normal 12 volt output on the PD.
5. Use a crescent wrench as a hammer. (power on or off, you choose.)
6. Hold a robot part in your hand while drilling. ( a variety of errors jump to mind)
7. Put a practice battery on the robot. (actually happens more than you know)
8. Build to last year's dimensions because "they never change".
9. Use a dremmel tool to grind right next to your custom 3D printed part.
10. Mount your bumpers upside down. (except teams 11, 111, 1111)
Unread 02-05-2013, 17:52
Re: Things you only do ONCE!
11. Solder without safety glasses.
12. Use a hand drill with long unbound hair.
Unread 02-05-2013, 17:55
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
13. Leave male ends of PWM cables exposed.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 02-05-2013, 17:56
Bstep's Avatar
Bstep Bstep is offline
FRC #1983 (Skunkworks Robotics)
Bstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of lightBstep is a glorious beacon of light
Design the robot with Mechanum wheels.
Unread 02-05-2013, 17:57
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
15: Leave a wrench on the draw bar on the Bridgeport and turn it on
16: Touch a freshly welded part
17: Touch a rough edge on carbon fiber
2015 GKC Engineering Inspiration
2015 Colorado Winners
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
We've done it twice.
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Do the trig for your autonomous mode during opening ceremonies and run the code untested in your first match.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 02-05-2013, 17:59
Kyle A's Avatar
Kyle A Kyle A is offline
If it ain't broke don't fix it!
AKA: K Adams
FRC #0306 (CRT(Corry Robotics Team))
Kyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud ofKyle A has much to be proud of
Send a message via AIM to Kyle A Send a message via Yahoo to Kyle A
18. Drill something without covering the electronics.
19. Put a popped of chain back on without cutting the power.
20. Spray paint a part outside in 20 degree weather.
21. stand in front of the robot while testing the shooter.
Corry Robotics Team 306 1999-2015
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
19. Stick your fingers into one of the big muffin fans accidentally.
20. Stand in front of a robot wearing a green shirt when the robot vision is set to look for a green target
21. Do a poor job tying down your fastener containers in your trailer on the way to IRI.
22. Put your finger on top of a piece of metal in front of the blade while cutting with a bandsaw.
23. Try to hold a piece of metal square into the sanding disk on a table sander
24. Forget to take the chuck out of a drill press with a plate-glass window behind it.
25. Grab a constant force spring and yank it off its top roller.
Unread 02-05-2013, 18:00
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Leave the key in the lathe chuck. Whatever you do don't do this.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 02-05-2013, 18:01
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
26. Push a team into the pyramid when they are lining up to climb.
Unread 02-05-2013, 18:02
Lead Bumper Mentor
AKA: Mike Marandola
Although it is funny to watch people jump after doing this when reaching in the robot.
Unread 02-05-2013, 18:03
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
24. Leave a chuck key in a lathe and turn it on.
25. Put 3 bolts between the sprocket and a Performance wheel, even though there is a very good reason why there are 6 holes.
26. Use a double sided intake for a ball game.
27. A week 1 regional.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 02-05-2013, 18:11
apb2390's Avatar
apb2390 apb2390 is offline
AKA: Andrew
FRC #1684 (Chimeras)
apb2390 is an unknown quantity at this point
Team 1684, The Chimeras, did this last year and it greatly increased our versatility. We were constantly happy to have it.
FRC 1684 (2012-2015)
2012: Programming
2013: Electrical
2014: Design / Electrical
2015: Design Lead / Electrical
4 Years, one Blue Banner. We did it.
Unread 02-05-2013, 18:12
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
28. Test your robot not on blocks when you have a "joystick" with a Y axis that's stuck at -1.
29. Leave your hand on a pinch point while someone's testing the robot. (Sorry Josh)
30. Spray paint an entire crate on a just cleaned concrete floor. Without newspaper.
31. Stand directly behind a spinning shooter wheel with a "temporary" tread on it.
32. Cut off zip ties with a knife with the blade up.
