Go to Post I searched the web for a good forum and it looks like this is the place to be. - Pipisongo [more]
Unread 02-05-2013, 09:54
Oblarg Oblarg is online now
AKA: Eli Barnett
Hardware Questions
I've been poking around various hardware suppliers, and haven't been able to find a couple of things that my team will likely need for the offseason. I was wondering if anyone around here knows where I might be able to obtain the following:
1) Hex shafts which are turned down to fit into circular bearings on their ends. AndyMark sells a couple of these for use in their gearboxes, but they're made of steel and they're too short - does anyone know if any supplier sells these in either 6061 or 7075, or would we need to just buy a hex shaft and lathe it ourselves?
2) 3/8'' hex-bore 5mm-pitch HTD belt pulleys.
The idea here is that we're designing something in which we'd like to keep as many parts off-the-shelf as possible, so lathing our own parts, or broaching our own hex bores, is unattractive.
"The breakfast of champions!"
Unread 02-05-2013, 10:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Hardware Questions
I'm sorry to say that you probably won't find such custom parts available off the shelf. This is a good time to look into buying that lathe, and that broach set and press.
Unread 02-05-2013, 13:20
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Is there a reason you cannot use a hex bearing on the end instead of round?
Unread 02-05-2013, 13:21
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
That second item is a prime candidate to be a 3D printed part. Once you start looking, it is surprising how many parts you find could be made this way. We had at least half a dozen unique parts in our robot this year which were 3D printed.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 02-05-2013, 13:24
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Sounds like you're just going to have to buy a .5" hex shaft and turn down the edge yourself. Shouldn't be too difficult if you do have a lathe.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 02-05-2013, 14:03
AKA: Eli Barnett
Would like to use flanged bearings and a construction in which the shaft holds the bearing in place. Construction would be more complicated, otherwise; it'd require shaft collars, and shaft space is at a premium.
Unread 02-05-2013, 14:13
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
We did that with our Vex Pro Ball-Shifter by taking out the short shaft and buying the stock from vex to lathe down the end to fit in a bearing. We could not find any prefabricated shafts to use. Hope this helps.
http://www.vexrobotics.com/vexpro/sh...aft-stock.html
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 02-05-2013, 17:41
If they are short, McMaster has threaded hex standoffs, in aluminum & steel. Then you could use a bearing on a bolt threaded into the standoff. Not cheap or easy, but no machining.
http://www.chiefdelphi.com/forums/ne...te=1&p=1271391
Unread 02-05-2013, 18:44
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You can also tap the end of the hex shaft and sandwich a thrust washer between bolt head and the flanged side of a hex bearing. It's not pretty, but could work in a pinch.
--Madison--
...down at the Ozdust!
Unread 02-05-2013, 19:18
MrForbes's Avatar
AKA: Jim
There are many ways to get out of buying a lathe, but there is so much more you can do when you finally get one, why keep putting it off?
Unread 02-05-2013, 19:26
AKA: Eli Barnett
We have access to a lathe; I was simply wondering if anyone sold the things so we wouldn't have to make them ourselves. Off-the-shelf parts are a huge benefit. It's not that we can't do it otherwise, it's just that one of the things we're going to be shooting for with this design is simplicity and ease of construction, which custom-lathed parts don't really fit into.
Ultimately, though, we'll likely end up lathing the things ourselves. That's what machine shops are for. I just wanted to make sure that we don't go with that if there's a way to avoid it.
Unread 02-05-2013, 19:34
CalTran's Avatar
Missouri S&T Senior
Why avoid using the machine shop you have in house?
Unread 02-05-2013, 19:46
AKA: Eli Barnett
It's not in-house.
Unread 02-05-2013, 22:31
DonRotolo's Avatar
Back to humble
FRC #0832
Sorry for the off-topic post:
A lathe is a machine, it is used to Turn parts, not lathe them.
Very unlike most other machining terms. Can anyone think of another machine where the work it does is not the name of the machine?
Unread 02-05-2013, 23:04
Billfred's Avatar
Billfred Billfred is offline
For our 2012 robot (and I want to say 2009, but it's been a minute since I saw it), we took hex shaft from McMaster-Carr and had our machine shop turn down the last little bit on each end (plus some E-clip grooves, but that's not relevant to your task). Since the bronze bushings we used were 1/2" and the shaft is 1/2" across the flats, all they had to do was round off the hex. Easy and fairly quick on any respectable lathe, so much so that I wouldn't try any quick-and-dirty techniques except in truly dire circumstances.
