Go to Post In real life, I use almost nothing I learned from football except that with a bit of hard work you can get somewhere. Oh, and I have bad knees on top of that. I could have (and wished I would have) learned that from a FIRST FRC team instead. - JesseK [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 02-05-2013, 19:30
Re: Things you only do ONCE!
50. Connect the battery's terminals with a pair of bolts.
51. Use a drill (press) and file/sandpaper as a lathe. I understand the BeachBots go through at least one lathe of that type per year on average.
52. Power on a mill with anything other than a tool in the cutter. (The bar used for tramming in the head survived, but the gauge didn't! And no, that wasn't me.)
  #32   Spotlight this post!
Unread 02-05-2013, 19:33
Oblarg Oblarg is offline
AKA: Eli Barnett
53. Attempt to cut hardened-steel shafts on a chopsaw (In my first year on the team, the head of drive mechanics attempted to do this. You can guess how it went. Ultimately, we turned the de-toothed blade into a pretty new clock for the shop teacher, as a consolation.)
54. Let the new electronics freshmen wire up 5 of your motor controllers, and attempt to run them without checking that they did it right. Great way to burn your money, literally.
55. Stall a fisher-price motor.
56. Reach out and flick the little-piece-of-bolt-hanging-on-by-a-thread-after-being-dremmeled with your finger.
57. Splice a PWM cable and a power cable in similar locations, and then proceed to tape the splices so that they're right text to each other. To this day I have no idea who did this, but it killed no less than three digital sidecars.
58. Leave a flashlight sitting in the drive train during an elimination match.
"The breakfast of champions!"
  #33   Spotlight this post!
Unread 02-05-2013, 19:36
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Originally Posted by Gregor View Post
27. A week 1 regional.
Our team... EVERY YEAR. >_>
53. Pull the PWM cable out of a speed controller and let the connector fall onto the +12v input terminal of said speed controller while the robot is powered on. (Fun way to make magic smoke though)
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
  #34   Spotlight this post!
Unread 02-05-2013, 20:07
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
54. Win the Chairmans award at the FIRST Championship.
... Unless you're 191.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
  #35   Spotlight this post!
Unread 02-05-2013, 20:23
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
55. Use window motors on something that should be fast
We managed not to learn from our first time.
  #36   Spotlight this post!
Unread 02-05-2013, 20:30
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
56. Use versa wheels.
1058 PVC Pirates 2016 - xxxx
  #37   Spotlight this post!
Unread 02-05-2013, 20:31
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
57. Leave the shooter motor unplugged before a match.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
  #38   Spotlight this post!
Unread 02-05-2013, 20:32
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Wire a kinect backwards. Not only did it destroy the kinect, it shorted the O-Droid X2 board it was plugged into. $250 dollars...gone.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
  #39   Spotlight this post!
Unread 02-05-2013, 20:35
Jorge Ayala's Avatar
Jorge Ayala Jorge Ayala is offline
FRC #3478 (LamBot)
Jorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to beholdJorge Ayala is a splendid one to behold
Originally Posted by Bstep View Post
Design the robot with Mechanum wheels.
+1
Website
Facebook
Twitter
Victory goes beyond winning.
  #40   Spotlight this post!
Unread 02-05-2013, 20:36
cpeister's Avatar
cpeister cpeister is offline
Mech Eng Student at Waterloo
AKA: Cale Peister
FRC #0781 (Kinetic Knights)
cpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud of
Send a message via MSN to cpeister
58. Cut spring steel with a hack saw.
Cale Peister - Team 781 Alumni
Mechanical Engineering Student at Waterloo
Attended: WAT'07, WAT'08, GTR'08, WAT'09, GTR'09, WAT'10, GTR'10, WAT'11, GTRE/W'11, BUCKEYE'11, CMP'11, GTRE'12, WAT'12, GTRW'12, WAT'13, WAT'14, WAT '15
  #41   Spotlight this post!
Unread 02-05-2013, 20:40
AKA: Simon Bohn
I don't want to break the flow of this thread, but why not?
  #42   Spotlight this post!
Unread 02-05-2013, 20:42
FRC #3478 (LamBot)
59. Design the robot before analyzing the game properly
(My team, three years in a row...)
Website
Facebook
Twitter
  #43   Spotlight this post!
Unread 02-05-2013, 20:53
AKA: Brendan Browne
Versas are amazing for about one match. They are the closest thing to a cleat you can use. After that they wear down extremely fast. They also don't have much if any lateral traction since the grooves only face one way.
We switched our drive wheels out a lot to keep traction throughout events.
  #44   Spotlight this post!
Unread 02-05-2013, 21:03
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Done that, cut the tip off a destroyed end mill to start turning it into a boring bar... but we used the correct abrasive blade...
  #45   Spotlight this post!
Unread 02-05-2013, 21:18
Eagleeyedan's Avatar
Eagleeyedan Eagleeyedan is offline
C.O.R.E.; We build on each other
AKA: Daniel C.
FRC #2062 (C.O.R.E. 2062)
Eagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the roughEagleeyedan is a jewel in the rough
This killed us in a match but it truly was only done once.
Former Driver and Safety Captain of team C.O.R.E. 2062 (Community of Robotic Engineers)
2015: Wisconsin Regional- Champions, Industrial Safety Award
Midwest Regional - Champions, Industrial Safety Award, Industrial Controls Award
2014: Midwest Regional - Judges Award
2013: Lake Superior Regional - Champions
2012: World Championship - Industrial Safety Award, World Finalist for the Autodesk Award
2011: Wisconsin Regional - Website Award 10,000 Lakes Regional - Innovation in Control, Safety Award
2010: World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
10,000 Lakes Regional - Regional Champs, Entrepreneurship Award
Wisconsin Regional - Entrepreneurship Award, Industrial Safety Award
2009: WI Regional- Quality Award, Industrial Safety Award
10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008: World Championship - Industrial Safety Award,
Wisconsin Regional - Champions, Industrial Safety Award
