Go to Post It would be wise to consider the reasoning behind the statement rather than the statement itself. Sometimes they are right... other times their statement is incomplete... and other times they really do have no clue what they are talking about. - dtengineering [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 02-05-2013, 22:05
apb2390's Avatar
apb2390 apb2390 is offline
AKA: Andrew
FRC #1684 (Chimeras)
apb2390 is an unknown quantity at this point
Re: Things you only do ONCE!
81. Try to program in LabView.
*ducks*
FRC 1684 (2012-2015)
2012: Programming
2013: Electrical
2014: Design / Electrical
2015: Design Lead / Electrical
4 Years, one Blue Banner. We did it.
  #62   Spotlight this post!
Unread 02-05-2013, 22:07
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
=+ 1. While programming autonomous for the next match "meh, 5 seconds should be good enough"
Queue Karthik "That robot isn't suppose to be there ?!"
2016: FRC 865 Mentor
  #63   Spotlight this post!
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by fb39ca4 View Post
And teams 1, 8, 88, 69, 96, 101, 609, 619, 689, 808, 818, 888, 906, 916, 986, 1001, 1691, 1881, and 1961. Any more I have forgotten?
1551, if you use blocky 5's!
What's not to like about rotational symmetry?
Also: great thread idea, Al!
Here's at least one:
Ram your largest sponsor in the shins with an unbumpered robot while demonstrating your drive train. (That was our first year; fortunately, the driver was her nephew!)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #64   Spotlight this post!
Unread 02-05-2013, 22:10
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
80. Grabbing a rivet after its been drilled out
81. Bend lexan with a heat gun
82. Use one robot appendage to do two different things (We had a scoop at the beginning of the year that we were going to use to pick up frisbees and hang. Needless to say, we took it off after our first district.)
83. Not weigh the robot until an hour before B&T.
84. Add a top-heavy FCS blocker to our robot.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
  #65   Spotlight this post!
Unread 02-05-2013, 22:19
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
How else does one bend lexan?
85. Forget to plug the wench motor that raises your arm for climbing in before a match and have the team try to blame the programmers when the arm won't move and the robot doesn't climb because the programmers were trying to make the lights do a disco flash at the top of the pyramid.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
  #66   Spotlight this post!
pfreivald's Avatar
We've done this on several robots with excellent success. Why not?
86. Get married the night before kickoff. (Anniversary? What's that?)
87. Forget to send thank-you notes.
88. Fail to zip-tie the Anderson Connectors for the battery/PD board.
89. Use a twist and some masking tape instead of solder on sensor wires, just for now to test it real quick, then never fix it.
Team 1551
I write books, too!
  #67   Spotlight this post!
Unread 02-05-2013, 22:21
Sorry, I meant thick lexan. When I did it, I melted the lexan and it was a very shady result.
  #68   Spotlight this post!
Unread 02-05-2013, 22:24
bgg's Avatar
bgg bgg is offline
FRC #3679
bgg is an unknown quantity at this point
90. Blame the programmers before you double check that the PWMs are all connected.
  #69   Spotlight this post!
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: lexan, whatever you do, don't lasercut it. We've got a nice big materials sign behind the lasercutter in the lab I work in, and next to "polycarbonate," in big red text, is "TOXIC FUMES: DO NOT CUT."
"The breakfast of champions!"
  #70   Spotlight this post!
Unread 02-05-2013, 22:27
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
91. Use jaguars for drivetrain CIM motors
  #71   Spotlight this post!
Unread 02-05-2013, 22:30
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
92. Use casters
93. Use a scissor lift
  #72   Spotlight this post!
Unread 02-05-2013, 22:31
AKA: Eli Barnett
As a previous member of 449, I would like to take issue with this.
  #73   Spotlight this post!
Unread 02-05-2013, 22:32
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
94. Drill above an uncovered Jaguar
95. Use solder the size of your index finger for 16 gauge wire
96. Wire the "Angle" terminal of the gyro get vi to the set motor value vi
97. Touch the robot while the gyro is calibrating
98. A barrel roll with your robot
99. Order pizza while that one guy who can eat 8 pieces of pizza is around
100. Let your laptop's battery die while coding
101. Test the robot for the first time without blocks
102. Walk 4.5 miles after your team's bus broke down
103. Hack code together to make something from a stock WPI library VI work
104. Make your pick-list based on average alliance score.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
  #74   Spotlight this post!
Unread 02-05-2013, 22:36
IndySam's Avatar
My statement stands.
  #75   Spotlight this post!
Unread 02-05-2013, 22:37
AKA: Eli Barnett
That was one of the best and most reliable systems we've ever had on a robot. It never failed. It never even required maintenance. Worked like a charm for every competition we attended, and for demos for years after.
It was also incredibly easy to make and not demanding in terms of precision, at all. Several pieces of angle-stock with three holes drilled in them, some bolts, and some nylon washers.
