Go to Post "If I say its name three times, will it appear in my lab?" - Madison [more]
Unread 02-05-2013, 22:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Frustrating solenoid valves won't open
Originally Posted by jnaranjo View Post
Our rookie team is building a pneumatic T shirt cannon in the off season.
We have a 24V FESTO double sided valve, and a 12V CKD single sided valve.
You're going to need a much larger valve to make the cannon work well. Those have very little flow. Look into how to specify valves using Cv, the flow co-efficient.
Also, consider running the system at a higher pressure (and using hardware designed for that).
Unread 02-05-2013, 23:57
jnaranjo jnaranjo is offline
FRC #4682
jnaranjo is an unknown quantity at this point
Thanks! Where would we find a valve suitable for our needs? We have a 120 psi circuit, but we intend to shoot it at a much lower psi. We actually don't know how much we need.
Unread 03-05-2013, 00:04
Take a look here for some ideas, many of which are not FRC-legal.
(It's worth prototyping with familiar valves first, before buying the huge one that 254 uses.)
