Go to Post I would proudly put an AndyMark sticker on our robot any day! - Andy Grady [more]
Unread 02-05-2013, 19:57
jnaranjo jnaranjo is offline
FRC #4682
jnaranjo is an unknown quantity at this point
Frustrating solenoid valves won't open
Our rookie team is building a pneumatic T shirt cannon in the off season.
We have a 24V FESTO double sided valve, and a 12V CKD single sided valve.
We are using standard components from the Kit of Parts.
On the 24V FESTO, we are using a 12V battery on the power distribution board, and we are wiring the solenoid to the 24V port on the power distribution board, but we don't know how 12V are magically turning in to 24V, or if they even are.
We have a simple pneumatic circuit set up, with a compressor, relief valve, pressure switch, and solenoid. We just want the solenoid valve to open when we energize it.
I've uploaded pictures of both of the valves. We are currently manually completing the circuit for each solenoid we test. For both of them, we hear clicking but no pressure is being released.
Both are 5 hole solenoids (3 on one side, 2 on the other).
We have the tube from the compressor to the #3 hole in the solenoid (the only one that does not let air through when not connected. It is the one on the side with three holes on one of the sides).
We have nothing connected to the output holes.
On the FESTO, we hear clicking when we power it, and we see a light come on.
We've tried flipping the polarity, and we've tried both sides of the double action solenoid.
On the CKD solenoid, we just hear clicking.
We've played around with the buttons on both solenoids (twisting, turning, pressing, depressing, etc...) and nothing happens. We've tested two FESTOs and one CKD.
If anyone has any suggestions on anything we could try to get these to work, we would be very grateful. We've been banging our heads against the wall for 3 days trying to figure this out.
Thank you!
ID:	14775  Click image for larger version
Unread 02-05-2013, 20:00
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Frustrating solenoid valves won't open
Thank you!
The compressor should be connected to port 1 on the FESTO.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 02-05-2013, 20:02
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
I believe that the air from the tanks/compressor connects to port 1 on the festo valve, and that the one you have it connected to is the exhaust. Also, it is designed to let pressure out of either port 4 or port 2. If you want to use the valve as a single valve (to fire a t-shirt) you should plug 4 and use 2 as your output. Also, this valve probably isn't the best for a t-shirt cannon, as it will let the air out slowly.
Unread 02-05-2013, 20:03
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Also these are pilot operating valves, they will not function without air pressure. The air actually moves the valves not the electricity.
Unread 02-05-2013, 21:14
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
What type of gasket do you have in between the solenoid and the solenoid bank? You may have one that has no holes in it that is used as a 'plug'.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 02-05-2013, 22:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
You're going to need a much larger valve to make the cannon work well. Those have very little flow. Look into how to specify valves using Cv, the flow co-efficient.
Also, consider running the system at a higher pressure (and using hardware designed for that).
Unread 02-05-2013, 23:57
FRC #4682
Thanks! Where would we find a valve suitable for our needs? We have a 120 psi circuit, but we intend to shoot it at a much lower psi. We actually don't know how much we need.
Unread 02-05-2013, 23:59
FRC #4682
Sorry about that, we actually were using the valve #1 on the FESTO valve initially. We just switched it to test the others out because we were desperate, and we just forgot to switch it back for the picture!
I did notice that some people suggested plugging the second outpuut port that we don't intend to use. Could that be the source of our problem?
Unread 03-05-2013, 00:04
Take a look here for some ideas, many of which are not FRC-legal.
(It's worth prototyping with familiar valves first, before buying the huge one that 254 uses.)
