Go to Post Remember that the reason that you do something should NEVER be for the sole purpose of winning an award. To paraphrase something said by one of the Hall of Fame teams: "You should choose to do something because it is fun and the right thing to do." - tim-tim [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 02-05-2013, 22:53
AutodeskGeek's Avatar
AutodeskGeek AutodeskGeek is offline
FRC #2062 (C.O.R.E. - Community Of Robotic Engineers)
Team Role: Driver
AutodeskGeek is an unknown quantity at this point
Re: Things you only do ONCE!
105. Have mini wars over whether it should be "shooterSubsystem" or "Shooter_Subsystem"
¤ Autodesk Geek
  #77   Spotlight this post!
Unread 02-05-2013, 22:57
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Camel case. Every time.
All opinions are my own.
  #78   Spotlight this post!
Unread 02-05-2013, 23:01
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
We ain't writing no dot-net in here.
My students hate my love of conventions for nameing. whitespace, casing, etc. I'm thinking of implementing checkstyle...
  #79   Spotlight this post!
Unread 03-05-2013, 00:13
Originally Posted by Oblarg View Post
That was one of the best and most reliable systems we've ever had on a robot. It never failed. It never even required maintenance. Worked like a charm for every competition we attended, and for demos for years after.
It was also incredibly easy to make and not demanding in terms of precision, at all. Several pieces of angle-stock with three holes drilled in them, some bolts, and some nylon washers.
That would be successes one, failures some much higher number. I've seen a couple that were very poor, and one or two that looked decent but didn't perform as you might expect.
  #80   Spotlight this post!
Unread 03-05-2013, 00:21
ttldomination's Avatar
Sunny
Why, in all that is holy, would you capitalize the words if you're using an underscore?
Pressing the shift key, ain't nobody got time for that.
- Sunny G.
1648: 2013-2014
5283: 2015
  #81   Spotlight this post!
Unread 03-05-2013, 00:27
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Originally Posted by BrendanB View Post
Versas are amazing for about one match. They are the closest thing to a cleat you can use. After that they wear down extremely fast. They also don't have much if any lateral traction since the grooves only face one way.
We switched our drive wheels out a lot to keep traction throughout events.
We've run the same versa's all season with very little wear. It's 8 wheel drop.
2015 GKC Engineering Inspiration
2015 Colorado Winners
  #82   Spotlight this post!
Unread 03-05-2013, 00:30
MStump's Avatar
MStump MStump is offline
AKA: Michael Stump
FRC #3309 (Friarbots)
MStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to beholdMStump is a splendid one to behold
106: Get everything ready for your first match and forget to plug in the shooter.
  #83   Spotlight this post!
Unread 03-05-2013, 00:47
moogboy's Avatar
moogboy moogboy is offline
Wiggling With Experience
AKA: Bubba
FRC #3175
moogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the roughmoogboy is a jewel in the rough
107: Leave the scouting iPad in the shooter chamber for the entire match, putting the robot overweight.
I'm Bubba. I make noise, sometimes it comes out as music, and I love robots.
  #84   Spotlight this post!
Unread 03-05-2013, 01:19
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Originally Posted by Eagleeyedan View Post
65. Manually cut a part with the CNC machine
Hmm why not?
I use the jog wheel/MIDI to run the machine for basic facing/cutting/drilling operations. Though for anything more then one or two holes I just type of a can cycle script.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
  #85   Spotlight this post!
Unread 03-05-2013, 07:44
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Originally Posted by Iaquinto.Joe View Post
57. Leave the shooter motor unplugged before a match.
Use code from 2 weeks ago in a match by accident
  #86   Spotlight this post!
Unread 03-05-2013, 07:52
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Originally Posted by bgg View Post
90. Blame the programmers before you double check that the PWMs are all connected.
You mean we're only allowed to do this once?
  #87   Spotlight this post!
Unread 03-05-2013, 07:57
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
108. Trust a programmer to not use your private parts to test the bridge manipulator.
109. Trust a programmer to not use your chest as a shooting practice target (happened in 2012, not 2013, fortunately).
110. Trust a programmer to not use your back to test the strength of a 'box manipulator' (part of our FLFL robot, a platform attached to a piston to change it's angle).
Having written this, I'm getting the feeling that programmer doesn't like me...
WOW! I didn't think this was going to grow so big. I may have to limit this to a thread that just talks about robot, then another that talks about wiring, and another about mechanical so we can all filter through everything. Thanks for the input so far and keep it up.
And another for injuries...
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
  #88   Spotlight this post!
Unread 03-05-2013, 08:25
kwotremb's Avatar
kwotremb kwotremb is offline
FRC #3414
kwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to beholdkwotremb is a splendid one to behold
108) Put the main breaker on the top of your robot only protected by a polycarb shield.
Lets just say that the totes from 2003 can deflect polycarb when the come crashing down when you hit the stack during autonomous.
2013: Team 3414 Hackbots
Waterford District: Finalist (51, 3604)
Livonia District: Winner (3641, 240), Spirit Award
MSC: 6th Seed Captain (862, 3641), Spirit Award
Worlds: Seeded 32 in Curie
Past Years:
Team 3414: Hackbots, 2013-Current, Mentor
Team 818: Steel Armadillos, 2008-2012, Mentor
Team 93: N.E.W Apple Corps, 2002-2003, Student
  #89   Spotlight this post!
Unread 03-05-2013, 08:29
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
Forgetting to turn on your robot right before a match, and watching it sit there for 2 entire minutes.
Mo Elhelw
FRC 1511 Rolling Thunder 10th Season Team Captain
Check out this awesome scouting project I've been working over the past year called FMS Scouting:
http://www.chiefdelphi.com/media/papers/3002
If you're tired of needing 6 people to scout or just don't have the resources, FMS Scouting is for you!
"The FIRST rule of FIRST Robotics is always talk about FIRST Robotics"
"Life's not linear"
2014 Finger Lakes Regional Chairman's Award Winner
2014 New York Tech Valley Regional Engineering Inspiration Winner
2013 Boston Regional Winners with 125 and 126
2012 Connecticut Regional Engineering Inspiration Winner
2011 DC Regional Chairman's Winners[/size]
  #90   Spotlight this post!
Unread 03-05-2013, 08:33
bbuncher12 bbuncher12 is offline
FRC #0540 (Talon 540)
Team Role: Electrical
bbuncher12 is an unknown quantity at this point
109. Build a metal-on-metal lift with no bearings or lubricant
110. Not cover the jags
111. Plug the power wires of a Spike into the motor output (it smells horrible)
112. Not put on a compressor because you assume that the pneumatics won't leak
113. Put Mechanums on backwards
114. Assume the CAD team will get the dimensions right
115. Not tell other subgroups that you're changing something (who am I kidding, we do this every year!)
Sometimes, you have to rely on a giraffe filled with whipped cream
--Frank Zappa
