#76
Re: Things you only do ONCE!
105. Have mini wars over whether it should be "shooterSubsystem" or "Shooter_Subsystem"
#77
Camel case. Every time.
#78
My students hate my love of conventions for nameing. whitespace, casing, etc. I'm thinking of implementing checkstyle... |
#79
Pressing the shift key, ain't nobody got time for that. - Sunny G. |
#81
106: Get everything ready for your first match and forget to plug in the shooter.
#83
107: Leave the scouting iPad in the shooter chamber for the entire match, putting the robot overweight.
#84
Hmm why not?
I use the jog wheel/MIDI to run the machine for basic facing/cutting/drilling operations. Though for anything more then one or two holes I just type of a can cycle script. |
#85
Use code from 2 weeks ago in a match by accident
#86
108. Trust a programmer to not use your private parts to test the bridge manipulator.
109. Trust a programmer to not use your chest as a shooting practice target (happened in 2012, not 2013, fortunately). 110. Trust a programmer to not use your back to test the strength of a 'box manipulator' (part of our FLFL robot, a platform attached to a piston to change it's angle). Having written this, I'm getting the feeling that programmer doesn't like me... Quote:
#88
108) Put the main breaker on the top of your robot only protected by a polycarb shield.
Lets just say that the totes from 2003 can deflect polycarb when the come crashing down when you hit the stack during autonomous. |
#89
Forgetting to turn on your robot right before a match, and watching it sit there for 2 entire minutes.
#90
109. Build a metal-on-metal lift with no bearings or lubricant
110. Not cover the jags 111. Plug the power wires of a Spike into the motor output (it smells horrible) 112. Not put on a compressor because you assume that the pneumatics won't leak 113. Put Mechanums on backwards 114. Assume the CAD team will get the dimensions right 115. Not tell other subgroups that you're changing something (who am I kidding, we do this every year!) |
