Go to Post You can't derail a thread that had no "rails" to begin with. - bkahl [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #91   Spotlight this post!
Unread 03-05-2013, 09:11
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
Re: Things you only do ONCE!
116. Not properly insulate the bottom of the gyro from the robot frame
117. Mount the cRIO is an area with serious danger of a falling lift (it still works...)
118. Use clippard air tanks. (Exploding a tank Thursday at Midwest regional makes the pits real quiet, even when it was only at ~30PSI)
  #92   Spotlight this post!
Unread 03-05-2013, 09:14
Michael Hill's Avatar
Michael Hill Michael Hill is online now
Originally Posted by Tom Line View Post
19. Stick your fingers into one of the big muffin fans accidentally.
This happens WAY more than once.
  #93   Spotlight this post!
Unread 03-05-2013, 09:58
Mgjohnson's Avatar
Mgjohnson Mgjohnson is offline
AKA: Grace Johnson
FRC #2481 (Roboteers)
Mgjohnson is an unknown quantity at this point
Originally Posted by Eagleeyedan View Post
66. Try to save time by putting the tap in a power drill
Originally Posted by Oblarg View Post
Who ever thought this would work?
It works. We did this while building our arm, but we used a mill.
  #94   Spotlight this post!
Unread 03-05-2013, 10:02
Joining the 900 Meme Team
FRC #0079
Originally Posted by Nick Lawrence View Post
54. Win the Chairmans award at the FIRST Championship.
... Unless you're 191.
-Nick
Except HoF teams can reapply after 5 years now... so... ?
  #95   Spotlight this post!
Unread 03-05-2013, 10:06
119. Mount the PD upside down, gravity works against the breakers.
120. Mount the radio inside a "U" shaped metal robot base to protect it.
  #96   Spotlight this post!
Unread 03-05-2013, 10:22
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
121. Assume a crimp connection is secure enough for any of your electronics.
2016: Lake Superior WFFA
  #97   Spotlight this post!
Unread 03-05-2013, 10:27
apb2390's Avatar
apb2390 apb2390 is offline
AKA: Andrew
FRC #1684 (Chimeras)
apb2390 is an unknown quantity at this point
If you can pull the crimp off of the wire, it wasn't strong enough.
FRC 1684 (2012-2015)
2012: Programming
2013: Electrical
2014: Design / Electrical
2015: Design Lead / Electrical
4 Years, one Blue Banner. We did it.
  #98   Spotlight this post!
Unread 03-05-2013, 10:28
Sam390250's Avatar
Sam390250 Sam390250 is offline
Positively Charged
FRC #0930 (Mukwonago B.E.A.R.s)
Sam390250 is a splendid one to beholdSam390250 is a splendid one to beholdSam390250 is a splendid one to beholdSam390250 is a splendid one to beholdSam390250 is a splendid one to beholdSam390250 is a splendid one to behold
Send a message via AIM to Sam390250
122. Place a powered up PCB onto an exposed metal plate
123. Cut an unknowingly live PWM cable
124. Set a battery and battery charger on fire simultaneously in a lunch room (this was not my doing by the way)
125. Use Lunacy wheels
126. Try to power a crab drive with a servo
If you're not intrigued, you're in trouble.
930's Harlem Shake (Only one broken leg ;] )
  #99   Spotlight this post!
Unread 03-05-2013, 11:36
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
127. Minibots. (surprised this hasn't been said yet)
128. Touch a part right after it's been welded
129. Use a hacksaw to cut a grove in a part on the lathe
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #100   Spotlight this post!
Unread 03-05-2013, 11:39
C. De Vries C. De Vries is offline
fountain of useless information
AKA: Christina
FRC #4531 (STEMpunk)
Team Role: CAD
C. De Vries is an unknown quantity at this point
Originally Posted by bbuncher12 View Post
114. Assume the CAD team will get the dimensions right
Hey! I think our CAD team does a fantastic job. I'm the only person on it, but I think we did okay...
130. Use Toughbox Nano Tubes.
What would you do if you did not fear?
______________
Wisconsin Regional Rookie All-Star 2013
Wisconsin Regional Highest Seeded Rookie 2013
  #101   Spotlight this post!
Unread 03-05-2013, 12:44
BrianArneson BrianArneson is offline
BrianArneson is an unknown quantity at this point
This^
131. Be the person who makes the bumpers. Everyone should experience it once, but only once
132. Touch a CIM after it just got burned out from being under too much stress and not think "hmm this might be hot"
133. Let someone decide to put mechanum wheels the wrong way so crawling is forward and normal is left/right for "strategic reasons" Even with gyro assisted driving it still never went in a straight line
7 year FRC participant
Mentor on FIRST Team 662 - 2 years
Former student FIRST Team 4550 - 1 year
Former student FIRST Team 443 - 4 years
  #102   Spotlight this post!
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
131. Waste a lot of programming time on vision processing only to have it not work at all at the event.
After one year of that, we learned our lesson.*
*Actually it took four years.
  #103   Spotlight this post!
Unread 03-05-2013, 14:11
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
n+1. Reach into that little area under the bandsaw platform, where little bits sometimes fall - while the saw is still moving...
n+2. Stay up until 4 AM a day you're volunteering at Championships to finish a project, only to realize the project isn't due until next week
n+3. The Kinect *ducks*
Does anyone else remember when TBA signatures actually worked?
  #104   Spotlight this post!
Unread 03-05-2013, 14:54
pfreivald's Avatar
AKA: Patrick Freivald
Really? We did that this year and experienced no problems... Good to know, though!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #105   Spotlight this post!
Unread 03-05-2013, 15:15
meibnotu's Avatar
meibnotu meibnotu is offline
AKA: Mei-Jing Bernard
FRC #5332 (Toaster Tech)
meibnotu is an unknown quantity at this point
Originally Posted by BrianArneson View Post
This^
For the bumpers.. twice in a row man -.- This is what happens when you're one of 3 at the shop at 4:30am.
134. Request that your sleep deprived (over 24 hours) mentor drives you, the shooter, and other mentors to a scrimmage.
135. Show up to Championships with 2 lock up forms and no unlock form.
136. Let your code say that the shooter wheel is absolutely NOT supposed to come on when using rmps.
137. Zip tie washers to a wheel to try and balance it.
138. Put yellow casting putty into the holes of the same wheel to try and balance it out.
139. Have your driver station somehow end up in the scrap bin.
2012 Peachtree Regional Highest Rookie Seed
2013 Winners of Peachtree Regional with 3489 & 4026
