Go to Post Let this be a lesson to everyone to never make changes to manufacturing drawings without issuing a new rev of the drawing itself... - Cory [more]
Unread 03-05-2013, 09:35
tj1673's Avatar
tj1673 tj1673 is offline
Collegiate Mentor
AKA: Trevor D.
FRC #0048 (Delphi E.L.I.T.E.)
tj1673 is just really nicetj1673 is just really nicetj1673 is just really nicetj1673 is just really nice
HSV/HSL Algorithm
Hello all,
I've been thinking about it, and was wondering:
What are the time and space complexities of the HSV/HSL algorithm that runs the vision processing?
Since it's just a simple loop through a set number of pixels, does that mean it is O(n)?
And I figure it can't take too much space based on the fact that all of this is happening on the cRIO.
"You are not the battles you’ve lost. You are the war you fight. You are not that shadows that fall. You are a home for the light."
Unread 03-05-2013, 11:31
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: HSV/HSL Algorithm
I can't comment on how the NIVision functions are implemented, but theoretically, since colorspace conversion is a per-pixel operation, it should run in O(n) time and O(1) space (if you don't count input/output space - especially since it can be done in-place; O(n) space if you do count input/output buffers).
FRC 766, 2015-, Mentor
Unread 03-05-2013, 21:10
I implemented this a few years ago and used an algorithm from Foley and van Dam. I found it by googling, but don't remember exactly which site I found it at.
It is O(n) time and can be done either inplace or into another buffer of the same size.
The NIVision algorithms strive for accuracy and I don't believe they use the approximation algorithm I mention above. I was told that the HSV is faster but less accurate than the HSL, but I haven't verified this.
Greg McKaskle
