Thread Tools |
Rating:
Display Modes |
Re: Team 254 2013 FRC Code
![]() We ported the style guide over from our C++ one before discovering the (many) limitations of Java ME. Enums aside, we could have made the constants management stuff a lot cleaner with generics and reflection. |
I did a diff on your CheezyGyro class, and the only important change was making initGyro() public. Is this only to calibrate the gyro when you want to? Why didn't you just adjust it in the wpilibj and compile with the custom version?
Then anyone checking it out would have to have the modified WPILibJ
Another question, I haven't seen a single final variable, even in cases where I can't see a good reason not to. Any reasoning behind that or is it just because you know you won't write code to mess with them?
#8
You actually can use the DPad up and down if the switch on the controller is set to D. Then it is axis 6.
#9
My compliments to Team 254's Programming team and mentors. That's some beautifully structured code you have there. I especially love how elegant your seven disc auto sequence is.
#10
Could you explain the purpose of the negative inertia maths in CheesyDriveCommand.java? Is it to limit the change in PWM?
#11
Thanks to everyone at 254 for the yearly release of your software. Since you began doing this, 254 software releases have been a source of inspiration and learning for me as a programmer. I especially appreciate the style guide. I will be using it to format 399 code for release later this month.
As a user of a variant of cheesy drive, I've observed that negative inertia calculations and outputs help prevent overshooting during turns by momentarily outputting a calculated output(whose sign is opposite the actual turning direction) to help act as a tuneable brake. This makes turning on a dime and other quick yaw-axis motions a little more controllable when coupled with the rest of the cheesy drive algorithm. Cheesy drive aids controllability on robots that are fast(14+fps) and can turn quickly because of that. Last edited by Jeremy Germita : 05-05-2013 at 23:33. |
#12
This route would require maintaining a fork of the library and requiring anyone who wants to build our software to use the forked library. Putting it in our source tree makes it easier to maintain AND gives the added benefit of giving compile time errors if something changes upstream.
#13
The bigger issue is if the other library receives updates from the original source. Then you have to re-implement the changes into the updates. If the custom change were in runtime logic (not detected by a compile error, like the Poof's would be) then your robot wouldn't act correctly, causing a lot of wasted time in trying to figure out why. Here's an example of a situation where I was forced to modify COTS code at work. It required a full write-up and sign-off by the program manager. This type of thing isn't detected by a compiler, but it caused several runtime Exceptions when we tried to load the map format. At work, we use NASA WorldWind. WorldWind has some static file name extensions that are hard-coded to lower case. On Linux, the files we have are upper case, and case matters on Linux. One of the map formats we use contains the upper-case file names in a header table embedded within a single file binary file -- not possible to change. Additionally, if the issue were brought up to NASA, the fix would likely be seen in WorldWind 1.5 or 1.6, whereas we're using 1.4. WorldWind 1.5, at the time the decision was made, was having hotspot issues on Linux -- so waiting for a fix in an update was considered a risk. Thus, we had to modify WorldWind's code (added .toUpperCase() in the proper spots). We then CM'ed the specific patch files so we would know exactly what changes had to be made in the future. Any time we want to update WorldWind (perhaps in the project's next iteration), we can pull the patch files out of the code repository and analyze if they're still relevant. |
#14
As a Java programmer, lets just say this has fulfilled the second letter of this great organization we compete in for me.
*picks jaw up off of floor* |
#15
Did Team 254 use visioning on OverKill? If not, how did the drivers line up to shoot so accurately?
