Go to Post Lawyers find loopholes. Engineers find solutions. For which would you rather be known? - dlavery [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 03-05-2013, 21:04
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Team 254 2013 FRC Code
Originally Posted by joelg236 View Post
I did a diff on your CheezyGyro class, and the only important change was making initGyro() public. Is this only to calibrate the gyro when you want to? Why didn't you just adjust it in the wpilibj and compile with the custom version?
Then anyone checking it out would have to have the modified WPILibJ
Unread 03-05-2013, 21:05
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
I suppose so. Although who would compile it? Not everybody has an Overkill
All opinions are my own.
Unread 03-05-2013, 21:07
AKA: Josh P.
Any other 254 programmer with a new dev environment?
AKA: Joel Gallant
Another question, I haven't seen a single final variable, even in cases where I can't see a good reason not to. Any reasoning behind that or is it just because you know you won't write code to mess with them?
Unread 03-05-2013, 22:31
xmaams xmaams is offline
AKA: Sam Dietrich
FRC #2587 (Discobots)
xmaams will become famous soon enoughxmaams will become famous soon enough
You actually can use the DPad up and down if the switch on the controller is set to D. Then it is axis 6.
Unread 03-05-2013, 22:41
apb2390's Avatar
apb2390 apb2390 is offline
AKA: Andrew
FRC #1684 (Chimeras)
apb2390 is an unknown quantity at this point
My compliments to Team 254's Programming team and mentors. That's some beautifully structured code you have there. I especially love how elegant your seven disc auto sequence is.
FRC 1684 (2012-2015)
2012: Programming
2013: Electrical
2014: Design / Electrical
2015: Design Lead / Electrical
4 Years, one Blue Banner. We did it.
Unread 03-05-2013, 22:57
AKA: Sam Dietrich
Could you explain the purpose of the negative inertia maths in CheesyDriveCommand.java? Is it to limit the change in PWM?
Unread 05-05-2013, 23:30
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Thanks to everyone at 254 for the yearly release of your software. Since you began doing this, 254 software releases have been a source of inspiration and learning for me as a programmer. I especially appreciate the style guide. I will be using it to format 399 code for release later this month.
As a user of a variant of cheesy drive, I've observed that negative inertia calculations and outputs help prevent overshooting during turns by momentarily outputting a calculated output(whose sign is opposite the actual turning direction) to help act as a tuneable brake. This makes turning on a dime and other quick yaw-axis motions a little more controllable when coupled with the rest of the cheesy drive algorithm. Cheesy drive aids controllability on robots that are fast(14+fps) and can turn quickly because of that.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 06-05-2013, 22:16
This route would require maintaining a fork of the library and requiring anyone who wants to build our software to use the forked library. Putting it in our source tree makes it easier to maintain AND gives the added benefit of giving compile time errors if something changes upstream.
