Go to Post Moat confirmed, he was only mostly wrong - swnylm [more]
Unread 04-05-2013, 10:18
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Massive Hit
Originally Posted by Kevin Sevcik View Post
I have to say, I have little sympathy for people who go to all the trouble of welding up a frame, only to grind all the reinforcement off. As you discovered there, unless you've done a proper bevel prep on the edge, a butt joint is quite likely to have low penetration and little fusion of the base metal. And so you can end up with fractures that follow the original seam quite impressively. Any time one of my mentors suggests we weld something up and grind it flush, I give them the evil eye and they usually decide that perhaps we don't actually need to grind it, actually...
When you drop the frame off to be welded and it comes back like that, you dont really have much of a choice
Unread 04-05-2013, 14:56
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Massive Hit
I've just always stayed with the frame while it gets welded to make sure it was done right then put it into powder.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 04-05-2013, 17:04
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Massive Hit
Erm. Well that certainly is a problem. Maybe proper weldment drawings in inventor with callouts for the welds? Then you'll atleast have papers to shake at someone when it comes back that way.
Who'd you have weld it up that didn't know that basic rule of welding, anyways?
Unread 04-05-2013, 17:42
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
Re: Massive Hit
Huh. My browser loads the first picture sideways. I've never seen that happen before.
Unread 04-05-2013, 17:50
Re: Massive Hit
Our sponsor who is world (And technically out of this world) class. I dont think the welder knew the kind of loads we abuse our machine with and thought it would look nicer (that part is true). We sent them some pictures after we had a good laugh about it, and we'll be collectively sure to make sure to be extra concerned with exposed frame.
The kids managed to drive an entire match without noticing, and we're pretty sure 16 hit us on our exposed face with those huge claw things they had at the time. A full speed collision with something like that would probably cause a lot of frames some grief.
Unread 13-05-2013, 00:36
three_d_dave
Posts: n/a
Re: Massive Hit
The problem with welding thin items like this is that full penetration welds can easily become full-blow through holes. It does look like no weld-prep was done, but if you don't call for any you won't get any. The other factor is to look at the teensy weld section you'd end up with.
A better approach is to bevel, weld, grind flush, and then put a doubler plate over the joint and a fillet weld around the doubler, which will end up with about 10 times the shear area you have there.
It's hard to see how the inverted-V is to fit in, but it also has very little to work with.
Unread 13-05-2013, 11:10
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Re: Massive Hit
A flush weld with the proper relief bevel and penetration would have been fine (it was 1/8" wall 1x2 6061 tubing). Had the welds not been ground flush it also would have been fine (as was the case for the NASA repair welds on one side only that lasted another regional and the championships). We told our sponsor NOT to grind these welds but after they were smooth and sexy the welder assured us that there was plenty of penetration. Lesson learned... we should have sent it back.
Unread 13-05-2013, 12:45
three_d_dave
Posts: n/a
Re: Massive Hit
No matter how skilled a welder, there are material properties to consider.
In extruded form it would have been 6061-T651:
tensile strength of about 45ksi and yield of 40ksi.
After welding is in the -T0 condition:
tensile strength of about 18ksi and yield of 8ksi.
Eventually 6061 will age back to T4 or so, which is pretty close (70%), but it requires heat treat to get to T6/T651 strength levels.
Compared to the base (original) material, a welded area in aluminum can be a significant weakness that needs reinforcement.
Unread 13-05-2013, 12:57
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Massive Hit
At Hub City we had a pretty fun collision with 16 . You can see the numerous places our frame split. We Covered the whole thing in tin foil and had it rewelded (This time without the faces being ground off). No issues. http://i.imgur.com/h1bglpH.jpg
This x 2.
I would prefer an open root weld in this situation over a bevel, less prep effort and virtually no chance of a LOF defect. I say having written WPSs and earned an AWS certification in TIG welding aluminum.
Unless the welder has (or had) a certification in the weld they did, they have no qualification to make such a statement. Welders are not generally structural engineers, "plenty of penetration" might not be strong enough even if the weld did have full penetration.
Also, as mentioned by three_d_dave, welded material is generally weaker and needs the extra material provided by the weld bead even with full penetration.
This is what a single-sided, single-pass aluminum weld should look like:
Unread 13-05-2013, 13:30
Re: Massive Hit
Agreed. I actually ran some FEA on the front portion of the frame and felt it was adequate (had it been properly welded) even with the reduced strength in this area. The front was actually lower on my list of concerns as there are fairly large cutouts and holes in a WCD frame that reduce the strength more than 70% in certain areas.
I should have inserted this in quotes or added an icon... I said this rather tongue in cheek. There was virtually no penetration.
Unread 14-05-2013, 17:53
Re: Massive Hit
For extra overkill points, the next time a welder says that, you can send the part off for ultrasonic inspection to see if it really does have plenty of penetration.
Unread 15-05-2013, 08:00
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: Massive Hit
Ha!
Heck, even a mirror to get a look at the back of the weld...
