| Thread Tools |
Rating:
Display Modes |
Replacement robot controller for cRIO
During a team meeting, I sat and looked at our miserably scraped 2012 robot. It had the cRIO and several electrical components removed for our current bot. As we all know, the cRIO setup is costly ($600), and I don't think any team can produce that much money each year for a new robot.
As a result, I looked into a replacement controller. I realize this will not be FRC legal, but the end goal is to revive old bots for presentation (and a ~$50 budget). I'm not worried about pneumatic control at the moment since this particular bot doesn't use them. All that's really needed is 8 PWM outputs. After some googling, I ended up with the BeagleBone Black. It has exactly 8 PWM outputs and seems very ideal for this project. Additionally, the API is BeagleScript, which runs on Node.js, and Node.js is my life. Does anyone see any technical limitations with this before I drop $45? It doesn't have to use any of the standard FIRST utilities (Drive Station), just remotely control 8 victors throw PWM. I'm am still open to suggestions for other boards. |
Re: Replacement robot controller for cRIO
The problem with the beaglebone is it does not have a Real time operating system. This means that there is a delay when inputting data and things don't always work in real time. This becomes an issue for safety as proccesing can become delayed as you can not expect it to processe an input in a certain time frame.
If you're looking for a cheap and simple set-up I would try the robot open http://www.team221.com/robotopen/ |
You can use an Arduino and an RC controller/receiver.
I've posted some code for controlling speed controllers with an Arduino, using bluetooth and the BlueBots app for Android, but there are a few other threads on the topic, too. http://www.chiefdelphi.com/forums/sh...5&postcount=12
I've tested the code, and it works great with dual CIMs and an UNO R3, can't see why it couldn't be modified to run 8 motors. It also has code to check for errors in data packets, and to shut the system down if a data connection is lost. If you need more processing power, just step up to a MEGA or DUE... just watch that the new Due processor has 3.3V I/O lines, as opposed to the 5V lines on the Uno and Mega. Jason |
Clearly I'm biased
![]() But the RobotOpen Control Shield is intended for this exact purpose. It connects directly to the sidecar, has a complete driver station app and supports most any feature you would need for a typical FRC robot. |
BTW if you use a programmable radio like a turnigy 9x you can program the radio to do tank and holonomic drive and eliminate the arduino all together
#7
Could you really just plug talons into the 8ch receiver that the radio comes with?
#8
Yup, you can do all the mixing on the radio.
#9
One more thing. If you go this direction I would strongly recommend getting the 9xr or upgrading the 9x to er9x with a ISP programmer. It will give you way more programming options.
#11
[quote=gluxon;1272241]During a team meeting, I sat and looked at our miserably scraped 2012 robot. It had the cRIO and several electrical components removed for our current bot. As we all know, the cRIO setup is costly ($600), and I don't think any team can produce that much money each year for a new robot.
As a result, I looked into a replacement controller. I realize this will not be FRC legal, but the end goal is to revive old bots for presentation (and a ~$50 budget). I'm not worried about pneumatic control at the moment since this particular bot doesn't use them. All that's really needed is 8 PWM outputs. |
#12
I am looking at this at the moment, and it will probably be what I will go with. When do you think it will be restocked?
#13
If your team has any spare VEX microcontrollers, they work great for controlling past FRC bots. They are a bit more expensive than the other options you are considering but they are reliable and easy to use. My team uses the older PIC microcontrollers for past FRC robots and other robots we've made for demonstrations.
#14
