Go to Post the usual Canadian thing - Karthik [more]
Go Back   Chief Delphi > Technical > CAD
Unread 04-05-2013, 16:23
1683cadder 1683cadder is offline
FRC #1683 (Techno Titans)
Team Role: CAD
1683cadder is on a distinguished road
Parameter help
I'm working on a part and created a bunch of parameters that I would like to use in other parts of my assembly. How do I export the parameters to other models? All the tutorials I have seen have not been very helpful.
Unread 04-05-2013, 17:15
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: Parameter help
I can't speak for Inventor but for Solidworks you can have a text file with parameters and equations and then link models to that file (Open the equations dialog, select Link to External File, and then select the text file with your equations and variables).
Unread 08-05-2013, 20:04
sleepyizme's Avatar
sleepyizme sleepyizme is offline
AKA: Jason
FRC #0694 (StuyPulse)
sleepyizme is an unknown quantity at this point
Send a message via MSN to sleepyizme
Re: Parameter help
In Inventor, you can use an Excel file with a list of parameter names and values. These can be linked into each part/assembly through the Parameters menu under the Manage tab. Another more tedious method is to link to the parameters from another Inventor file (ipt, iam, etc), which can be done the same way.
