Go to Post It is amazing how much a person's participation in FIRST can shape his/her character. - Jupee [more]
Unread 01-05-2013, 16:51
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
4334 2013 Robot Code
We're proud to release our code this year. Although the code isn't extremely well documented, the API behind it is so everything should make sense.
https://github.com/joelg236/robot-code13
Ask if you have questions.
All opinions are my own.
Unread 05-05-2013, 10:44
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
Re: 4334 2013 Robot Code
Is there supposed to be a branch called "depreciated", or did you mean "deprecated"?
Unread 05-05-2013, 12:33
AKA: Joel Gallant
It's supposed to be depreciated... Why deprecated?
Unread 05-05-2013, 13:45
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Depreciated means that it has diminished in value over time. Deprecated means it is no longer in use.
I think you mean deprecated, unless they mean different things in Canada
Unread 05-05-2013, 14:41
AKA: Joel Gallant
No, it definitely is depreciated. It's for old code that isn't as useful as it once was, considering we've replaced it with new code. It's also not in use anymore, but the important part is that it's been replaced.
Unread 05-05-2013, 16:26
commodoredl commodoredl is offline
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
I'm fairly certain the industry term for what you are describing is in fact "Deprecation."
http://en.wikipedia.org/wiki/Deprecation
Not to be confused with Depreciation.
Deprecation is a status applied to a computer software feature, characteristic, or practice indicating it should be avoided, typically because of being superseded.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 05-05-2013, 16:32
AKA: Joel Gallant
I stand corrected. Well I'll be sure to switch that for next year.
Unread 05-05-2013, 17:12
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
The ThreadableCommand looks unique.
Can you tell us what the robot does in autonomous mode?
Unread 05-05-2013, 18:10
AKA: Joel Gallant
ThreadableCommand just gives everything the option to be run in a new thread. It's convenient for button mapping when you want it to start a new process instead of delaying everything.
Auto is just 3 discs. It uses a scripting language (gordian) to run the commands necessary. The variables are in the text file, so we don't need to recompile every time.
