Go to Post You know, I have 2 big addictions in my life right now: ice cream, and FIRST. While the prior may not be great for my health, I think I'm doing just fine with FIRST. - Beth Sweet [more]
Unread 05-05-2013, 15:57
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Team 1806's 2013 Code
https://code.google.com/p/2013swat-r...e%25 3Dclosed
To check it out, it works best if you have Tortoise SVN (http://tortoisesvn.net/) and check out from http://2013swat-robot-code.googlecode.com/svn/trunk/
Admittedly it might be a bit of a spaghetti-like jumble, and it's not documented incredibly well, but it worked. Feel free to ask any questions about what something does or how/why we did something.
We'll try to make it a summer project to retroactively clean it up and comment it better.
Also it was our first year using an SVN system for code management, which was a huge success.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 05-05-2013, 16:14
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Team 1806's 2013 Code
How does SVN work for labview? Did you have any specific problems?
All opinions are my own.
Unread 05-05-2013, 16:16
Woolly's Avatar
Programming Mentor
Well, you can't diff or merge very well to my knowledge, but otherwise as far as committing, branching, updating, etc. it works very well. It's good just to have you code in the cloud so every member on the team can access it, and having a backup copy you can access from anywhere you have internet.
Unread 05-05-2013, 20:59
I use compare more often than merge. I generally don't need to merge and instead just review that my changes make sense.
I attached an image of what diff looks like. The window on the bottom shows the description of the diff and the upper two windows are the two files with the objects selected and some items circled.
Greg McKaskle
Unread 05-05-2013, 23:07
Here's how to set up graphical diffing and merging for TortoiseSVN. It would be similar for other tools.
https://decibel.ni.com/content/docs/DOC-2936
Unread 06-05-2013, 13:24
bumblebee3339's Avatar
bumblebee3339 bumblebee3339 is offline
Team's main account
FRC #3339 (BumbleBee)
bumblebee3339 is an unknown quantity at this point
Is there a way to download it without the SVN?
Unread 06-05-2013, 15:18
Woolly's Avatar
Programming Mentor
Greg McKaskle
Alright, there's actually a toolbar inside of labview for all that stuff, definately will be helpful for summer projects and next year. Thanks!
Here's a rar file of it! http://2013swat-robot-code.googlecod...lds%202013.rar
