Go to Post The game is leaking? That can only mean... - GeeTwo [more]
Unread 05-05-2013, 20:24
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
paper: FRC1477 2013 Robot CAD Files
Thread created automatically to discuss a document in CD-Media.
FRC1477 2013 Robot CAD Files by James Tonthat
Unread 05-05-2013, 20:25
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: paper: FRC1477 2013 Robot CAD Files
Just spent the last hour or so getting lost in this model. There's some really, really cool stuff in here.
So awesome, thanks for posting this.
-Dustin Benedict
Unread 07-05-2013, 10:46
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Thanks so much for this! I know my team and I will be dissecting this and looking very closely at it.
Unread 07-05-2013, 11:58
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Very nice, thanks for posting this. Couple questions...
1) It looks like there are 2 different types of encoders on the shooter pitch angle. Is this just for redundancy? If so, why two different types?
2) What type of machinery do you have access to? Manual mills/lathes, CNC milling, laser sheet metal, etc.
Unread 07-05-2013, 12:46
1. We were playing around with using incremental encoders for differential output so we could do motion profiling (with a US Digital S4), what we ended up using is the US Digital MA3 encoder which gives an analog output (0-5v). We had originally used the MA3 directly on the tilt shaft but that would only give us 1:1 resolution on the angle of the shooter. We ran it back through a 14T to give us 5.14 times the resolution so noise on the analog breakout would appear "smaller". This basically allowed us to use about 85% of the sensor's rotation and resolution to give us better readings. Also, I just realized the "shooter tilt" doesn't reflect what was on the robot. It's simply a BAG Motor, 100:1 Versaplantery, 14T spur gear to a 72T mounted to the holes there and the motor is mounted to the holes there, that "kit" with the two extra 14T's on the Versaplanetary don't exist in real life.
2. It varies from year to year. This year we primarily relied on CNC milling, all the 0.25" plate and tubing you see was done on Team Kaos 1429's mill that they graciously let us use. The 0.090" and 0.125" aluminum sheetmetal was done at Innovation First's sheetmetal shop, all of it was designed to be CNC punchable. In our shop, we have a small hobby lathe that we can turn out small parts that don't necessarily need a lot of precision. At UT-Austin, I do the more precision lathe parts on a collet lathe with a 5C 1/2 hex collet at a machine shop there. Also in house, we have a CNC router (that we mainly do plastics on) with about a 18"x18" work envelope and a small (tiny) CNC lathe that we can do small metal parts on. We have fantastic sponsors that allow us to build the way we do but every year we're flexible on design techniques and resources to make sure we're best utilizing all our resources.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
