Go to Post remember to keep this simple but yet complex everyone - Team#2057-Vegas [more]
Unread 04-05-2013, 13:54
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
Replacement robot controller for cRIO
During a team meeting, I sat and looked at our miserably scraped 2012 robot. It had the cRIO and several electrical components removed for our current bot. As we all know, the cRIO setup is costly ($600), and I don't think any team can produce that much money each year for a new robot.
As a result, I looked into a replacement controller. I realize this will not be FRC legal, but the end goal is to revive old bots for presentation (and a ~$50 budget). I'm not worried about pneumatic control at the moment since this particular bot doesn't use them. All that's really needed is 8 PWM outputs.
After some googling, I ended up with the BeagleBone Black. It has exactly 8 PWM outputs and seems very ideal for this project. Additionally, the API is BeagleScript, which runs on Node.js, and Node.js is my life.
Does anyone see any technical limitations with this before I drop $45? It doesn't have to use any of the standard FIRST utilities (Drive Station), just remotely control 8 victors throw PWM. I'm am still open to suggestions for other boards.
Unread 04-05-2013, 14:08
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Re: Replacement robot controller for cRIO
The problem with the beaglebone is it does not have a Real time operating system. This means that there is a delay when inputting data and things don't always work in real time. This becomes an issue for safety as proccesing can become delayed as you can not expect it to processe an input in a certain time frame.
If you're looking for a cheap and simple set-up I would try the robot open http://www.team221.com/robotopen/
2016: FRC 865 Mentor
Unread 04-05-2013, 18:08
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
You can use an Arduino and an RC controller/receiver.
Unread 04-05-2013, 18:20
dtengineering's Avatar
AKA: Jason Brett
I've posted some code for controlling speed controllers with an Arduino, using bluetooth and the BlueBots app for Android, but there are a few other threads on the topic, too. http://www.chiefdelphi.com/forums/sh...5&postcount=12
I've tested the code, and it works great with dual CIMs and an UNO R3, can't see why it couldn't be modified to run 8 motors. It also has code to check for errors in data packets, and to shut the system down if a data connection is lost.
If you need more processing power, just step up to a MEGA or DUE... just watch that the new Due processor has 3.3V I/O lines, as opposed to the 5V lines on the Uno and Mega.
Jason
Unread 04-05-2013, 23:07
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Clearly I'm biased
But the RobotOpen Control Shield is intended for this exact purpose.
It connects directly to the sidecar, has a complete driver station app and supports most any feature you would need for a typical FRC robot.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 04-05-2013, 23:14
mman1506's Avatar
no team (WARP7)
BTW if you use a programmable radio like a turnigy 9x you can program the radio to do tank and holonomic drive and eliminate the arduino all together
Unread 04-05-2013, 23:18
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Could you really just plug talons into the 8ch receiver that the radio comes with?
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
Unread 04-05-2013, 23:20
mman1506's Avatar
no team (WARP7)
Yup, you can do all the mixing on the radio.
Unread 04-05-2013, 23:25
FRC #3476
Awesome! Thanks.
Unread 04-05-2013, 23:28
mman1506's Avatar
no team (WARP7)
Awesome! Thanks.
One more thing. If you go this direction I would strongly recommend getting the 9xr or upgrading the 9x to er9x with a ISP programmer. It will give you way more programming options.
Unread 05-05-2013, 00:24
xisybyl xisybyl is offline
FRC #3648
xisybyl is an unknown quantity at this point
[quote=gluxon;1272241]During a team meeting, I sat and looked at our miserably scraped 2012 robot. It had the cRIO and several electrical components removed for our current bot. As we all know, the cRIO setup is costly ($600), and I don't think any team can produce that much money each year for a new robot.
Unread 05-05-2013, 18:48
gluxon's Avatar
\n
AKA: Brandon Cheng
Originally Posted by ajlapp View Post
Clearly I'm biased
I am looking at this at the moment, and it will probably be what I will go with. When do you think it will be restocked?
Unread 05-05-2013, 19:41
bnardone64 bnardone64 is offline
AKA: Brian Nardone
FRC #0229
bnardone64 is just really nicebnardone64 is just really nicebnardone64 is just really nicebnardone64 is just really nice
If your team has any spare VEX microcontrollers, they work great for controlling past FRC bots. They are a bit more expensive than the other options you are considering but they are reliable and easy to use. My team uses the older PIC microcontrollers for past FRC robots and other robots we've made for demonstrations.
Unread 05-05-2013, 20:55
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
It is in stock on Andymark
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 05-05-2013, 21:40
AKA: Anthony Lapp
Exactly.
Anthony Lapp
RobotOpen
