Go to Post I believe you have the right to develope your own opinion. I would suggest it be based on actual experience and facts. - Mike Copioli [more]
Unread 08-01-2002, 10:54
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Question How hard is it to pull a goal?
I tried pulling the goals at kickoff @ Manchester, and those goals were really hard to pull... Even when it was just one goal. I had to set up my position, legs pointing forward, back bending backward, and really try hard to pull one...
THEN, I went back to GRT and visit, and saw a custom goal they built, and pull on that, and it was considerably easier... Then I started IMing people, and people who went to manchester kickoff said the goals were hard to to move around, and people who went to San Jose kickoff said the goals aren't that hard to pull...
So, I am wondering if teams can do me (and to everyone) a favor, and use one of those spring scale, or a force meter, and figure out how much force it take to pull a goal. Two number would be nice: the force it take to get a 0 velocity goal moving, and the force it take to keep a goal moving...
Thanks!
Unread 08-01-2002, 12:23
Patrick Wang Patrick Wang is offline
#0115 (MVRT Alumni)
Patrick Wang has a spectacular aura aboutPatrick Wang has a spectacular aura about
Send a message via AIM to Patrick Wang
Several things to consider
There are several things that you need to consider to make a "goal pulling" experiment somewhat accurate.
First of all, the position of the casters is important when you start to move the goal. If the casters are in the correct position for movement in that particuliar direction, the force required to move it is considerabally less.
Secondly, you need to consider that for a human to push/pull a goal is different than a robot pulling or pushing a goal. While humans were designed to move forward, a robot could care less which direction it moves. (4-wheel drive tank drive train).
Just as a frame of referance, We did a few tests concerning the pushing/pulling of goals. We used our last year's robot to try and push the goals.
Our last year's robot was basically a 4 wheel trive tank system.
Drill motors were set at low gear for the experiment, and our gear ratio is 3:1.
We were able to move one goal at a pretty good speed.
We were able to move a goal with a 130 lb guy standing on it at a good speed as well.
We were able to move a goal with a 130 lb guy and 180 lb guy standing on it at a moderate speed.
Our wheel started to slip when we had a goal 130 lb guy 160 lb guy and 180 lb guy.
You can get a lot of stuff to move with a reasonable drive train.
Patrick Wang
WRRF
Unread 08-01-2002, 14:20
Jestin McCarthy Jestin McCarthy is offline
AKA: JT Money
#0131 (C.H.A.O.S.)
Jestin McCarthy has a little shameless behaviour in the past
Send a message via AIM to Jestin McCarthy
Re: Several things to consider
pushing and pulling won't be that hard. It is the turning aspect that will put the stress on the motors.
Unread 08-01-2002, 15:37
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
If you don't mind sharing, what was your wheel diameter with this set-up?
Thanks
Matt B.
Unread 08-01-2002, 16:13
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
Not all casters are equal
Last year we purchased the specified casters and some "cheaper" ones. The goals made with the cheaper ones were CONSIDERABLY HARDER TO MOVE. In fact, after forgetting about the mixed casters, we decided that there would be lots of variation in goal resistance and decided to not try to drag goals around. Oops. In fact with the casters specified the goals are pretty easy to move around.
Well, let me qualify that: we used the "good" casters from last year. Perhaps this year FIRST spec'd the cheaper ones that Home Depot sells. I better check that out before we repeat last years mistake.
We too, use the Bosch in low gear with a final drive of 3:1. Plenty of power to slip wheels on the carpet. With gear switching, top speed is a respectable 10fps as well. (6" wheels turned down to 5.75" - flat)
Cheers!
Team #492
Unread 08-01-2002, 16:45
Anton Abaya's Avatar
Anton Abaya Anton Abaya is offline
None #0419 (Rambots)
Anton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura aboutAnton Abaya has a spectacular aura about
Send a message via ICQ to Anton Abaya Send a message via AIM to Anton Abaya
we are still waiting for our goal to be built...i'll try to publish some results asap.
Unread 08-01-2002, 21:32
SuperMark SuperMark is offline
SuperMark is an unknown quantity at this point
Cool It's easier then you think!
The goal isn't as hard to move as most people (especially those on my team) think. When i was at the kickoff event in my area (Toronto) the goal moves along the floor with little to know effort. I'll admit, when the wheels are turned in a different direction it will be a tad harder but not that much, as long as you use good quality wheels you should be fine.
"Remember that time your dog ate my goldfish, and then you told me i never had a goldfish? Why'd I have the bowl Bart, Why'd i have the bowl?"
Unread 09-01-2002, 00:51
#0115 (MVRT Alumni)
More info.
To answer your question, we were using 8 inch wheels with treads cut horizontally across them.
speaking of turning, that is certainly something that we need to test. I'll see if I can do that with our old robot tommorow.
Patrick Wang
WRRF
Unread 09-01-2002, 03:34
Dima Dima is offline
Dima is just really niceDima is just really niceDima is just really niceDima is just really niceDima is just really nice
Send a message via AIM to Dima
while we are on the goal topic
did u guys notice that the ANGLE IRON was different at the kickoff goals and they are saying that is the RIGHT WAY, and the BLUE PRINTS are WRONG what do u guys think? O and BWT we "attached" our last years robot to 2 goals and the robot could make a wide trun with both on and a turn around itself (the center of the bot) with 2 people standing on it!
Unread 09-01-2002, 10:10
nick reynolds nick reynolds is offline
Senior Member
nick reynolds is on a distinguished road
I can see one problem that could cause FIRST a headache. As the Goals are all placed in the same place to start the game and most Robots will aproach the Goals from the same direction, then I can see the carpet getting some what thread bare in those places especialy with the weight of the Goals and the need for torque.
Nick237
Unread 09-01-2002, 11:11
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
Why are you worried about moving the goal. the goal is the easy part.
Moving a goal when someone else is trying to pull it from you is going to be the hard part.
if you make a robot that is going to be just able to pull the goal you will be under powered
Unread 09-01-2002, 16:12
President, VEX Robotics, Inc.
Moving goals easy ...
Moving the goals is pretty easy, but that is if noone is tugging on any of the goals. Attached is our robot from last year pushing 3 goals. Our latches from last year don't work on these goals and we aren't planning on destroying last years robot, that is why we are pushing it.
Some details:
Wheel diameter = 8"
Motor type = drill in low
gear ratio = 2:1
drive type = 4 wheel skid steer
tire material: Front - timing belt; Rear - Confidential
Disclaimers:
1. We did not modify last year's robot at all.
2. We performed this experiment to get a data point on how hard it would be to move 3 goals
3. As you can see in the video, our speed was pretty good
The million dollar question: Will this be enough???? Time will tell.
NOTE: The voice at the end is mine. I didn't know he was recording sound.
Well, I just got the message that I can't upload the movie and I don't want to delete everything. Does anyone know what I can do to upload the movie?
Unread 09-01-2002, 22:40
Zac Louden Zac Louden is offline
#0103 (Cybersonics)
Zac Louden is an unknown quantity at this point
Send a message via AIM to Zac Louden
when we built our goaoland tested it with last years robot it tokk 80 pounds of pressure to move the goal.
Unread 09-01-2002, 23:12
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
2 batteries will do it with castors aligned
At our remote kickoff, someone tied a cord around two of our batteres and ran the cord through a pulley to the goal. If the castors were prealigned, the weight of the two batteries would (barely) move the goal.
Team 1062, The Storm, 2003
Unread 10-01-2002, 22:11
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Exclamation We measured the force ........
We measured the force (straight pull) it takes to move the goal on the carpet from a resting state using a fancy strain gage. It averaged out at around 32-35 lbs.
Ed Sparks
MECH TECH FRC-3959
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team #237 2001 Robot - "Nineteen foot six" archiver 2001 13 24-06-2002 00:59
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
