#136
Re: Things you only do ONCE!
Why exactly was it a bad idea? Too much friction? Did it get caught on something?
#137
At our regional this happened but the FTA saved us the match 210. If you use a classmate they have chargers at the alliance stations |
#138
210. our classmate wasnt updated, our computer was compatitable with the charger, and even though it shut off at the wall, it booted up fast enought that we ended up playing that match |
#139
You never need to disconnect the radio from the cRIO. Plug the tether from the laptop into any of the other radio ports, while still maintaining connection with the cRIO.
#140
I'm assuming that he was talking about 2010 or 2009, when the radio only had one port.
#141
no it was this year. i have never heard of that though, im the only one on my team who knows how to do any of the wiring or programming stuff. And the mentor i used to have never showed me that.
#142
211. Forget to turn the robot on before a match starts
212. Break 2 drill bits in 1 day 213. Get attacked by killer treading 214. Try to defend against 2485's Sun Tzu. <3 (over 50 penalties called, I didnt realize they were touching us) Last edited by kghaemi96 : 07-05-2013 at 01:10. |
#143
Also because your blocker may end up breaking... Just sayin'. 45 mph, 3300 rpm. I'm aloud to brag about that because I was in no way involved in the bild team ![]() |
#144
NOTE: We were a team with (i think) no mentors at the time. |
#145
Unfortunately, the programming team is the wiring team, so either way. We blame ourselves either way.
#147
There was a day when we got bored at work many years ago. While looking at a Murphy's Law poster we decided to come up with ridiculous units for measurement. From the poster, 'furlongs per fortnight' jump to mind. We then decided to make another for measurement for length and came up with the femto (10^-15) parsec, then the kilo microwatt. We also received a piece of equipment that had a warning label on it that stated "Do not connect to a power supply in excess of 115,000 millivolts." Just when we thought we had seen it all, we received a specification in our rental agreement that we had to provide a TV signal from our transmitter to the building RF distribution that "must be no less that 1,000,000 microvolts." While that sounds harmless enough, our transmitter at the time was capable of producing 866,000,000 microvolts.
#148
I've been known to give distances in attoparsecs... (How tall are you? Oh, about 58 attoparsecs...)
#149
215: use one Victor 888 and one 884 on the drive system then spend a week trying to figure out why the wheels are rotating at different speeds.
216: not test 215 until after competition season is over. Yay for offseason events! 217: give the robot to the programmers for essentially the first time around 6 PM on practice day. (Ok maybe this one is wishful thinking...) |
#150
If you are a Mork & Mindy fan, that would be nano-nano parsecs....
