Go to Post Thank you GDC, for keeping everyone honest! - dtengineering [more]
Unread 05-05-2013, 16:09
bumblebee3339's Avatar
bumblebee3339 bumblebee3339 is offline
Team's main account
FRC #3339 (BumbleBee)
bumblebee3339 is an unknown quantity at this point
Talking How can I get an angle from a potentiometer?
As I know, you can use a potentiometer only as an analog I/O and get only the voltage.
How can I use this voltage to get my shooter angle for example?
Unread 05-05-2013, 16:41
Suitster's Avatar
Suitster Suitster is offline
AKA: Ethan Pellittiere
FRC #3951 (SUITS)
Suitster is on a distinguished road
Re: How can I get an angle from a potentiometer?
Assuming that your potentiometer has a linear output, all you need to do is create a linear equation. The way that it was accomplished on our team was we would measure the voltage and the actual angle at two positions, then solve for m and b, from there.
2012 FLR Regional Champs, with 1507 and 191
Unread 06-05-2013, 11:45
Team's main account
Oh, Ok
Thank you !
Unread 06-05-2013, 12:01
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Even if the potentiometer reading isn't linear (i.e. there is a linkage that connects the potentiometer to a point on the arm), it's fairly simple to get a good equation. Plot several calibration points in Excel, then use the "Add Regression Line..." option by right clicking on the graph. Then select the various equation types until you have a line that best-fits the data. Selecting the 'Show Equation on Chart' will give you the equation to program.
Just make sure the potentiometer readings are on the X axis.
GitHub
Unread 06-05-2013, 13:02
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Depending on the quality of your Potentiometer you can use a simple formula to compute it's voltage reading to it's degree. I've used this with fairly good results. It all depends on much accuracy you require.
For example, let's take a 340 degree single turn pot....
Roughly we know it's voltage is from 0v to 5v.....
So if it we take 5v / 340 that means it's 0.0147 volts/per degree.
Take your voltage reading and divide it by your volts per degree to get your angle.
300 degree pot would be 0.0166 volts per degree.
270 degree pot would be 0.0185 volts per degree.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 06-05-2013, 17:18
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Also be careful of the potentiometer you purchase. 10k resistive ones work well, but you really want to make sure you purchase a linear pot and not an audio pot. Pots for audio are not even close to linear....
Unread 07-05-2013, 09:12
Team's main account
I like your way of thinking
I'll use that
Unread 07-05-2013, 11:12
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
That's because they are logarithmic
http://en.wikipedia.org/wiki/Potentiometer#Resistance.E2.80.93position_relation ship:_.22taper.22
http://team2168.org
Unread 07-05-2013, 12:10
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We had 3 pots on our robot this year, all connected to our climbing arm. For us, it wasn't a question of developing an equation that would convert between voltage and angle... it was figuring out what values matched the specific angles we wanted. For that, we had a "test" mode, where the pot values were spit out on the console. We simply manually moved the arm to where we wanted and read the values at that point! It took a little fine tuning, but those values could then be fed directly into our PID loop to get the arm to perform exactly the same for every climb.
2016: Lake Superior WFFA
Unread 07-05-2013, 12:23
apb2390's Avatar
apb2390 apb2390 is offline
AKA: Andrew
FRC #1684 (Chimeras)
apb2390 is an unknown quantity at this point
Originally Posted by otherguy View Post
Most commercially available 'log' pots, like the ones you get at radioshack and Fry's, have more of a two-stage adjustment, as it's cheaper to make two parallel sections of resistive material than to actually taper the resistive material in a logarithmic fashion.
More info here: http://sound.westhost.com/pots.htm#taper
FRC 1684 (2012-2015)
2012: Programming
2013: Electrical
2014: Design / Electrical
2015: Design Lead / Electrical
4 Years, one Blue Banner. We did it.
