Go to Post I'm excited. Probably too much, but eh, I'm a big geek. - Brandon Martus [more]
Unread 07-05-2013, 09:38
bbuncher12 bbuncher12 is offline
FRC #0540 (Talon 540)
Team Role: Electrical
bbuncher12 is an unknown quantity at this point
Battery Leads Coming Loose
To connect our batteries to the battery leads, we use a small bolt and locknut and torque them down to make sure that the battery leads do not come lose, then we cover the lead and connection to the battery in heat shrink tubing. However, we have been having issues with the leads becoming loose and flopping around because the bolts are not holding well. What methods do you use to keep the battery leads attached to the battery, and do you try to avoid this problem? Thanks!
Sometimes, you have to rely on a giraffe filled with whipped cream
--Frank Zappa
Unread 07-05-2013, 09:45
lpickett's Avatar
lpickett lpickett is offline
Linda Pickett
FRC #1730 (Team Driven)
lpickett is a jewel in the roughlpickett is a jewel in the roughlpickett is a jewel in the rough
Re: Battery Leads Coming Loose
Battery leads will eventually loosen with the constant vibrations of playing the game. We do not use heat shrink so we can retighten the connections. You just need to have a system to check these on a periodic time frame. Just use black and red electrical tape to cover the terminal and bolts to protect from accidental sparking. You can also use nylock nuts. These are the ones with the plastic lining inside that grips and stays tight longer. The heat shring should only be used on the ends of your wire and lug terminal. We solder our connectors and crimp to ensure a good connection, then we use black and red heat shrink found at the local automotive supply store to cover the connection and make for a neater looking cable.
Unread 07-05-2013, 09:47
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
We usually use Crimp-on lugs. You need to have a decent crimper due to the force required. Typically we've noticed two reasons for leads coming loose. The first is the leads were not tightened enough. The second is people picking up batteries by the leads rather than the body.
Unread 07-05-2013, 10:01
@lpickett: Good to know we aren't the only ones, we'll try out using electrical tape and soldering them, thank you!
@adciv: Yeah, we've had a lot of trouble with people picking them up by the leads, they just don't pay attention Are you suggesting crimping the leads directly to the terminals, or something else?
--Frank Zappa
Unread 07-05-2013, 10:36
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We crimp/solder the leads to lugs.
Every team member/parent/mentor needs to know NEVER pick up the batteries by the cables. Rule #2 right behind wearing safety glasses.
Unread 07-05-2013, 11:14
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
FRC 2789 crimps leads as well. We've found that Home Depot carries the Thomas and Betts line of compression lugs, and they work very well. If you do crimp, don't fall for any "heavy duty" language on the packaging...that usually just means a thicker wall on the lug and hence bad compression.
To crimp, we use McMaster# 7061K12 plus an arbor press (no, we don't hit it with a hammer to compress like the instructions suggest). If you go this route, make sure you crimp into and out of the face of the lug. Going sideways means you don't get the right geometry since you aren't pressing into the split part of the lug.
After crimping, we could solder, but we find it isn't necessary. We do heat shrink over the shank of the lug, but not over the whole connection.
To attach to the battery, we use a nut-bolt combination (McMaster# 91241A773 and 96278A411) that includes a spring-type lock washer and a toothed washer (both are captive so nothing gets lost). AND NO OTHER WASHERS! Extra washers on battery terminals may feel like a good thing to do, but in the end they just provide extra surfaces for slip to occur at, and that causes all sorts of bad news when vibration starts.
We've had a great deal of success with this, when the fastening is done correctly.
Also, if you get that crimp tool and some 6AWG wire (preferably welding cable style), then you can purchase the un-assembled APP disconnect from Andy Mark and make your own battery cables. Our BOM cost on these is about $6.75, which is less than half the cost of the pre-assembled cable. This also means you get just the right lengths for the run from the robot side of the disconnect to the main breaker and PDB. VERY CONVENIENT! (Particularly when done with welding cable)
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 07-05-2013, 12:05
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We crimp and solder our leads into the compression lugs. After that, we attach with a lock nut, bolt, and star washer to help prevent twisting. Cover the whole thing with heat shrink.
In our 7 years, we've only had a couple of batteries come loose (we check them a few times each year - at kick off, before each competition, and before our fall program starts)... when that does happen, we take off the heat shrink and check all the hardware. If anything isn't working like it should, it gets replaced and we get everything tight and reapply heat shrink.
It's also extremely important NOT to pick up the battery by the leads! This can cause internal damage to the battery that will stop it from working properly, and kill the battery! This isn't something that should be "people not paying attention"... this should be pounded into everyone's heads so much that if anyone even sees someone else do it warning bells go off.
2016: Lake Superior WFFA
Unread 07-05-2013, 12:38
fb39ca4 fb39ca4 is offline
FRC #1899
fb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to allfb39ca4 is a name known to all
If you have a good soldering iron, I recommend soldering them.
Unread 07-05-2013, 13:00
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
We use the same crimper and but with a hammer, I don't think we've ever had any issues with the wiring mechanically coming out. We just make sure we're doing the crimping on a solid concrete floor.
These are the type of crimps (McM#7113K249) that we use. We also use #4 AWG wiring instead of #6. It's a highly stranded car audio wiring that we use. Something very similar to this Stinger Pro Translucent Red
Andy has pretty good pricing on the SB50 connector and terminals but we buy ours through Powerwerx along with our other APP products. (Warning: the other colors have different connector geometries so only buy red.) We use to use this crimper for the SB50 connectors but I'm not sure if we do it any more. I'll have to check in with our electronics students.
James Tonthat
Mechanical Engineer, RackSolutions
Texas Torque - 2009-2014
Robowranglers - 2015-
Unread 07-05-2013, 13:01
Thank you all so much, we will experiment around with these suggestions! But yeah, it is extremely annoying when people pick up the batteries by the wires, we put up signs, remind people constantly, and have had several announcements about it before meetings, but there's always that one person who forgets or is in a hurry who picks one up by the wires
--Frank Zappa
Unread 07-05-2013, 15:14
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
We crimp our leads. Like some others have said, with the heavy vibrations and the constant swapping of the batteries, a lead is bound to come loose eventually. To prevent this we have a checkout sheet that our pit manager fills out before every match. On this sheet there is a checkbox for making sure the battery connections are tight. So I would say the best way to make sure your connections don't loosen during a match is to check them before you head to queue.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 07-05-2013, 15:25
apb2390's Avatar
apb2390 apb2390 is offline
AKA: Andrew
FRC #1684 (Chimeras)
apb2390 is an unknown quantity at this point
Adding another $0.02 here, we tend to use either screw terminal lugs or hard crimps. I crimp using a square end punch and a hammer, or a phillips screwdriver in a pinch.
Well-crimped leads don't come loose. I've tested this by hanging a 6-inch length of 6-gauge wire with crimped lugs on the pyramid and hanging 130 lbs (myself) on it. Sat there for about 3 minutes, nothing came loose. Hung some additional weight (somewhere around 220 lbs) on it, still no sign of breakage.
FRC 1684 (2012-2015)
2012: Programming
2013: Electrical
2014: Design / Electrical
2015: Design Lead / Electrical
4 Years, one Blue Banner. We did it.
Unread 07-05-2013, 16:07
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
  • Use good quality finely stranded wire. (I like welding cable. Car stereo cable is fine if insulation durability isn't a huge concern.)
  • Use the right terminals for the wire. (I like to use the solid copper, tin-plated crimp sleeve terminals designed specifically for the wire gauge, with a #10 screw hole.1)
  • Use a a high-quality crimping tool. (Last time I bought one of those, it was less than $40 CAD. $65 is the best price I could find today; they're often well over $200 now. Consider the style Home Depot currently sells, but be aware the results may not be satisfactory due to the differently-sized crimping dies.)
  • The barrel of the terminal can usually accommodate two crimps with the tool. The whole process is completed within about two minutes (once you get used to stripping fine-stranded wire with a utility knife, without nicking the conductors too badly), and I've never had one fail.
  • The same procedure applies to Anderson SB50 and SB120 terminals; use the sleeve-type (not stamped) ones, and crimp once.
1 FIRST has often supplied ones with a Ø0.25 in screw hole. These don't fit the provided battery screws nicely.
Unread 07-05-2013, 16:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Something we've found that helps immensely is to bend the two leads so they are pointing toward eachother. Where the leads cross, we zip tie them together with a huge ziptie. Then we zip tie them above that so they are in a single lead.
We used to put a hole in 'handle' piece of the battery to zip tie the wires, but we've been told that any modification of the battery is illegal, so we don't do that any more.
Here's a sketch.
Unread 07-05-2013, 16:48
Mentor, LRI, MN RPC
Yes, that is illegal, and a huge safety concern. What happens if your drill goes a little too far when making that hole? You drive right into the battery, causing damage and a potentially dangerous situation (battery could internally short and catch on fire/explode, it could leak/spray battery acid, etc) For the sake of everyone's safety, there is a blanket safety rule against any modification of the battery beyond attaching the leads with appropriate fasteners.
