Go to Post Don't you hate it when you can't find the droids you're looking for? - Jared Russell [more]
Unread 07-05-2013, 20:12
Sherrardtr Sherrardtr is offline
FRC #2172
Sherrardtr is an unknown quantity at this point
Network table problems
Hello everyone,
I have been trying to develop an off board image processing program for my team. The actual image processing works fine but when I try to send the data back to the robot, it gets a little sketchy. On the laptop side I am putting number onto the network table with the following( in a nutshell ):
NetworkTable table;
Table.getTable("key").putnumber("X" , -1);
Everytime I try to put the number to the table, which is when it sees a square, the video feed freezes. However when I remove the square from the view of the camera, e feed resumes.
I guess what I am asking is, what would be the proper way to transmit data from the laptop (driverstation) to the robot?
Thank you!
Unread 08-05-2013, 12:08
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Network table problems
Can you provide a little more info on when you're calling:
And a description of the hardware setup might help too.
Just a guess without knowing a little more about your situation...
When a target is in the view of your camera, are you flooding the dashboard/robot with data? The video freezing on the dashboard is indicative of something between the camera and dashboard getting real busy. Again, just a guess.
http://team2168.org
Unread 08-05-2013, 12:58
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
If your dashboard is a simple display of the stream from the camera, this would be it.
If your dashboard is a display of your "processed" image, then it could be a problem in how you are sending your data. I don't have experience with sending images, so maybe someone else can fill that in for me.
All opinions are my own.
