Go to Post many of the greatest innovation throughout history have come from people who have ignored standard practices and traditional thinking. - jason701802 [more]
Unread 04-30-2013, 06:39 PM
pipsqueaker pipsqueaker is offline
FRC #1124
pipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to allpipsqueaker is a name known to all
[Q] How are we supposed to use threads in our robot code?
Hey, I'm a new programmer, and right now me and one of my friends are involved in porting our robot code to c++. One big thing that's been throwing me off however is c++'s apparent lack of threads. Whenever I google it I get suggestions to use the Boost library, which I have no idea how to use with WPILib. Results are even harder to find because of the clash of terminology (Google keeps confusing forum threads with code threads), so the end result is that I'm really not sure how (or if) I can thread the code.
I'm building off of the SimpleTemplate project, if you wanted to know.
Thanks!
Unread 04-30-2013, 07:10 PM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: [Q] How are we supposed to use threads in our robot code?
Thanks!
Last time I checked (around 1.38), Boost will work on vxWorks. However, compiling it into your robot code will be annoying. [edit] So don't use that on the robot unless you know what you're doing. [/edit]
Use the Task class instead, that allows you to create additional threads using WPILib.
Unread 04-30-2013, 09:43 PM
FRC #1124
Are you saying that I have to use boost and WPILib's task class? I looked on WPILib's task documentation page , and it doesn't look like I need to. Just looking for clarification.
Also, on the above page, it says the task::run takes the arguments of types FUNCPTR and int. just asking, the fcptr is just the function name without any arguments or parentheses, correct? Also the arguments are of type int, does that mean I can only pass integers?
Sorry for bombarding you with questions but, like I said, I'm new to this and have no coders on the team experienced enough with c++ to help us.
Unread 04-30-2013, 09:47 PM
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
I would take a look at pthreads.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 04-30-2013, 09:53 PM
virtuald's Avatar
RobotPy Guy
No.
Yes.
Sorta. Since it's C++ and it allows you to shoot yourself in the foot, you can technically pass in anything that is the same size as an integer. Be wary of this behavior, as integer sizes may vary on other platforms (such as your PC).
I recommend searching these forums for more information, other people have asked the same questions.
Unread 04-30-2013, 09:55 PM
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
You will never need to use Boost or any external libraries for any multithreading in C++ for FRC, so save yourself some headaches and just WPILib because it works like a charm.
Here's some code that makes a separate thread to flip the state of a relay, which is spawned at TeleopInit, and killed off at DisabledInit.
class Robot: public SimpleRobot{
  Task secondThread;
  Relay *relay;
 public:
  Robot():
   secondThread("SecondThread",(FUNCPTR) Robot::threadFunction)
   relay=new Relay(1);
  void threadFunction(UINT32 relayPointer){
   Relay *rly=(Relay*)relayPointer;
   while(true){
    rly->Set(Relay::kForward);
    Wait(1);
    rly->Set(Relay::kReverse);
    Wait(1);
  void Disabled(){
   secondThread.Stop();
  void Teleop(){
   secondThread.Start((UINT32) relay);
START_ROBOT_CLASS(Robot)
See also:
http://www.chiefdelphi.com/forums/sh...ad.php?t=82398
If you need explanation of anything in this post, just refer to that post^
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Last edited by Toa Circuit : 04-30-2013 at 10:01 PM. Reason: Realizing a few things
Unread 05-08-2013, 03:51 PM
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
My team produced a class this year which worked quite well and is quite extensible. All the source is on github. I also gave a pretty complete training discussion about how the class works and why in:
http://www.chiefdelphi.com/forums/sh...87#post1232587
If you have questions after reading that, feel free to contact me or post here. or there.
Thanks,
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
