Go to Post Everyone better enjoy the broadcast, Dave had to cancel a shuttle launch to make it happen :D - The Lucas [more]
Unread 08-05-2013, 16:27
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
Re: Record Robot Actions
Originally Posted by notmattlythgoe View Post
We set up recording on our drive last year and actually used it at the competitions for our hanging since it was so sensitive. What we did was record the values going into the motors instead of the joystick values. So for the drive all we had to do was save the values for the left and right sides and then play those values back again. We actually are working on getting this set up for the rest of the robot this off season also.
So I grasp the concept of recording but how would someone save those and play it back?
[Any example code? ....in LabVIEW]
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
Unread 08-05-2013, 16:30
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Unfortunately, we did ours in Java using the command based code design. So what we did was started a command using the drive subsystem and each run through of the command we appended the values to the end of a file. Then to play it back we started a new command that read the top line off of that file and sent the values to the subsystem. Using that structure all of the timing was handled for us. We are doing a complete code rewrite currently to clean up the implementation, I can get you samples of our code at some point if you'd like.
Unread 08-05-2013, 16:33
AKA: Sarah Storer
Personally text based code makes WAY more sense to me...I don't know a ton about LabVIEW but its what our robot is coded in:/....
Unread 08-05-2013, 16:36
Flywheel Police
Is there a specific reason that you guys used Labview? We switched to Java last year and have absolutely loved the Command Based system. We had used Labview before that, main reason for switching was the use in school and both the other mentor and I were better versed in it.
You can see the recording used in this video to hang on the lower bar. Our driver lines up under the bar and pushes a button and the robot drives backwards and drives forward. This was recorded on the practice field at the competition when we realized that our hanging mechanism was very sensitive to the speed that you hit the bar at. After the recording was done it was an extremely reliable mechanism.
http://www.youtube.com/watch?feature...NufVQ#t=12 1s
Unread 08-05-2013, 16:44
AKA: Sarah Storer
Because there is theoretically more support for LabVIEW and because its supposed to be "easier" because its visual.....I fail to see the easy part:/ But I don't think we can switch to anything else because I know more [even though its just a little] LabVIEW than Java or C++ or something like that...
Unread 08-05-2013, 16:47
Flywheel Police
Now would be the time to switch if you wanted to try a text based language. A great off season project if you wanted to learn one of the other languages is to reprogram the robot in another language. If you would like, once we finish the code rewrite I can send you all of our robot code so you can see what the code for a robot would look like.
Unread 08-05-2013, 22:37
The first attached image shows one way to record all data from one joystick every 20ms until the Done button is pressed. It then optionally saves it to a file. This code would fit well into periodic tasks.
The second image shows how to read all of the data from file and play it back at the same rate.
You probably don't need all six axes of the joystick, and you may want to record more than one. If that is the case, modify the data that goes into the cluster.
If you want to record the motor values and solenoid/relay values instead, that is an easy alternative and can be output from the Drive Robot function, accumulated, and logged.
If you decide to store sensor values and add control loops to the playback, that is indeed harder, and I'd recommend instead that you put that code into Drive Robot and store the set points.
If you are worried about memory usage, you most likely don't need more than 50 elements per second for no more than 15 seconds, or 750 elements in the array. The full joystick data is 50 bytes per element. Even if you store lots more values, for 1KByte per record, you still haven't used a megabyte, so you shouldn't have any memory issues. If you want to optimize for memory, you can move the file I/O inside the loop to avoid the largish array, scale the values from doubles to smaller values, use timestamps to compress the data, or do all sorts of other fun things.
As for switching to a different language, or practicing the language your team used this year, the off season is a great time to do it. I don't know of anything in command based programming that would make this any easier. Personally, I'd encourage you to become familiar with several of the languages as they each have unique features and values.
Greg McKaskle
ID:	14798  Click image for larger version
Unread 09-05-2013, 08:14
Flywheel Police
Greg McKaskle
I agree completely Greg. No one language is better than another, and it is a great tool to have knowledge of several different languages.
Unread 09-05-2013, 10:30
AKA: Sarah Storer
Thank you so much for the pictures that should help a lot!
I will probably look into C++ in the off season..but this and vision processing in LabVIEW will come first... [Our team is also working on making an encyclopedia for everything in FRC so that'll take some time too...]
I'll bring this up to our coach and we'll try it out
Unread 09-05-2013, 20:27
Be sure to fix my misspelling in the path.
Greg McKaskle
