Go to Post I can't help looking at the new center piece my wife put on the dinning room table and think to myself, "non-functional decoration" - DarrinMunter [more]
Unread 08-05-2013, 22:30
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: Highest traction wheels
Originally Posted by Michael Hill View Post
I think there are a couple of misconceptions here. There contact area will actually not be increased by that much with a wider wheel. It sounds odd, but the pressure that would be applied over a thinner wheel is now spread out over a wider one. That lower pressure doesn't allow the tread to expand as much along the wheel. However, because your width is greater, the contact area is roughly the same.
Second, drag racers have wide tires solely because of heat. You need big tires to dissipate it all. The stickyness that happens does, in fact, increase traction because it now brings in adhesion (your coefficient of friction is now >1). It literally is pulling the car down when this happens. However, in our situation, our wheels aren't producing near enough heat to do any of that.
Another thing to remember is that friction is very inexact. It's been seen in some circumstances that the coefficient of friction can change with respect to load (which goes against classical friction theory). There may be many other factors that come in to play as well.
In pneumatic tires or equivalent, this is true. Widening the tire will not change the contact patch, the patch will grow wider but shorter. Thus the way to increase the contact patch is to make the wheel a bigger diameter. I need to dig around to find the book I referenced this from.
However, for solid wheels I do not think this is totally true. I think it behaves more like a rack and pinion. I think the contact patch is small, so to make it bigger is to make the wheel wider. As with gears, you can't make more teeth mesh, but you can make the teeth wider to hold more load (assuming the DP is constant). If your "teeth" on your wheel can hold more load, you have more traction. Of course this can't be totally true because the wheels sink in the carpet a bit.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 09-05-2013, 08:50
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
We've done some static friction coefficient testing on both carpet and polycarbonate surfaces and found that the HiGrip wheels are excellent. We, however, did not test Colsons (even though we used them last year) or Versa wheels (yet - we have purchased a set for testing).
We test on two axes: the in-drive direction and perpendicular to this.
I agree that friction coefficient (between the wheel and driven surface) and the normal force applied between these two surfaces (generally the robot weight) are the key factors in determining traction.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 09-05-2013, 09:21
pfreivald's Avatar
AKA: Patrick Freivald
Anecdotal evidence from this past season indicates that Colson wheels to not grip as well as wedge top on carpet, but are absolute beasts on smooth surfaces...
...rattin' smattin' octocanum redesign...
So on a related note, what's the smallest wheel you can find (say, 2" diameter) with excellent carpet grip?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 09-05-2013, 09:24
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
A custom wheel with tread of your choice i prefer mcmasters blue nitrile tread personally
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 09-05-2013, 09:48
pfreivald's Avatar
Cool. Do you have a part number?
Team 1551
I write books, too!
Unread 09-05-2013, 09:52
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
can't tell if your making a comment about the custom wheel part number or asking for the tread part number, but either way the tread part number 5994K852
Unread 09-05-2013, 09:53
pfreivald's Avatar
Tread! Thanks!
Team 1551
I write books, too!
Unread 09-05-2013, 10:30
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
no problem its worked good for us for the last two years. Last years bots tread finaly started to show significant wear after the season during demos while we were driving on pavement and concrete
Unread 09-05-2013, 11:11
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
I've heard good things about cutting tread into Colsons like so: http://www.team228.org/gallery/125/b...3511-8f172.jpg
I have no concrete evidence that this increases traction, but I know 228, 125, and I think 1477 all cut their tread like this so perhaps someone from one of those teams can chime in here with some data.
In response to Pat's questions about extremely small traction wheels, the only COTS ones I can think of are Colsons and Banebots, and even the hardest (blue) Banebots wheels would have to be changed too often to be worth it. I would at least explore the possibility of cutting treads into Colsons, because the alternatives are machining intensive.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 09-05-2013, 12:28
pfreivald's Avatar
Cool -- that's easy to do, and the Colsons we're using are cheap enough to ruin without feeling bad about it!
Team 1551
I write books, too!
Unread 09-05-2013, 13:25
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
IIRC, I've heard numbers of 1.4-1.5 COF being thrown around when talking about Colsons with treads cut into them. Don't quote me on that, as I'm not 100% sure, but I will try to confirm when I get a chance.
Originally Posted by JamesCH95 View Post
Physics teachers the world over repeat this simplification. It is not true in real life. Coefficient of friction is a function of contact pressure for every traction system I've seen, namely coefficient of friction increases as contact pressure decreases.
(really awesome stuff removed to keep post length reasonable)
This is the theory I've learned and experienced with race car design/driving and some FRC teams have demonstrated through testing robot wheels.
This, all of this.
One thing that I'd like to add, is there's also a 'cleat-ing' effect (mechanical interaction) between some wheels and carpeted surface. Roughtop Tread (any form, though harder is better) and the 'W' tread on versawheels are both good examples of materials where this comes into play.
Think of something like a plastic carpet runner, the kind with little plastic spikes on one side and a textured surface on the other. If you applied traditional friction models to them, you'd see that the math just doesn't add up. (or shouldn't add up) If you dig into this a bit more, you'll start to see that the spikes dig into the carpet and make it seem like there's more friction between the two surfaces than there really is.
-Dustin Benedict
Unread 09-05-2013, 15:40
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
We used 6" x 1.5" Colsons this year in a 6 wheel system with about 1/4" centre drop (which was too much). The drive team loves them. It's pretty difficult to tell if they're better with or without tread but after reading other threads on Colsons, we cut a diamond pattern tread in them using a dividing head on a horizontal mill. A thin slit saw set to cut about 0.100" deep slot on 15 degree intervals and about 15 degrees of parallel seemed about right. After 3 regionals and championships they show little wear. We did experience some lateral shifting of the wheel on the hubs we used but only on one or two of the outer wheels. Next year, we'll cut a coarse thread in the hub before pushing them in and maybe use a bit of PL Premium to help.
Unread 10-05-2013, 15:36
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
http://teamwhyachi.com/wheels.htm
45a tread. 2.25" dia
priced in the lol price range at $41
you could also modify a pulley like mcmaster part #6235K72 to work as a wheel.
My Instructables
Unread 10-05-2013, 18:39
pfreivald's Avatar
Sounds like "buy bar stock and use a lathe" to me!
Team 1551
I write books, too!
Unread 09-05-2013, 11:48
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by MICHAELABICK View Post
I believe some of your statements are incorrect. Usually, the only variables that affect traction are coefficient of friction and weight. Because wider wheels just mean that the same weight is spread over a larger area, you have the same amount of traction. This is different when roughtop tread and carpet interact, because the roughtop "locks" in witht he carpet and increses the amount of traction you have with wider wheels. This is also like drag racing, where they heat up the wheels so that they "stick" to the ground and wider wheels have more traction.
To answer the OP's question, I have heard that colsons have the most traction on flat surfaces.
There have been a number of tests done by forum members/teams indicating the wider wheels provide more grip with the same normal force... however I haven't been able to find the posts mentioning this yet.
You're making a simplification here, heat is not the only reason to use a wider tire/wheel. Wider tires/wheels allow for the use of softer tread compounds that might wear too quickly on a narrower wheel by virtue of having more material available to wear away.
A wider wheel/tire will generally have a contact patch with a more uniform pressure distribution than a narrower wheel/tire due to the wheel's/tire's structure's effect on the contact patch. The wider wheel/tire can thus generate more grip because the coefficient of friction is a function of pressure, and the wider wheel/tire has a lower peak pressure in it's contact patch compared to a narrower wheel/tire.
I suspect that the analogy of car tires to typical rigid robot wheels fails at one important premise: rigid wheels do not maintain the same contact area vs width because they do not have a controlled contact pressure (i.e. tire pressure). Thus a wider robot wheel could very well have a larger contact pressure.
