Go to Post But plywood is so awesome on robots...... But I guess shiny usually always wins out huh? - Jon K. [more]
Unread 08-05-2013, 17:25
MoMo MoMo is offline
FRC #1721
MoMo will become famous soon enoughMoMo will become famous soon enough
6 Wheel Tank Drive
Is it possible to program 6 sims on 6 different jags with tank drive? i tired programming it with the frc c++ simple template but it wont let me add 6 jags only 4 any help?
Unread 08-05-2013, 18:21
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: 6 Wheel Tank Drive
The easiest thing to do is just mirror the output of the 4 you can control to the two that you can't add to robotdrive. Set the third left side jag to the value of the 1st one and do the same for the right side. Make sure you do this at the bottom of the periodic loop so it gets called every time.
You could also make your own class that inherits from robotdrive but accepts 6 speed controllers in it's constructor and handles them properly.
Unread 08-05-2013, 19:00
MathMaven MathMaven is offline
AKA: Elisha Sword
FRC #3175 (Knight Vision)
MathMaven is on a distinguished road
Alternatively, you can just brute-force your way through and code each Jaguar manually. It's ugly, but gets the job done.
—Elisha Sword
2010–13: FRC Team 3175 (Knight Vision), student, lead programmer
2012–13: FRC Team 3175 (Knight Vision), lead website designer
2014: FRC Team 3175 (Knight Vision), programming mentor
“Who has not been amazed to learn that the function y = e^x, like a phoenix rising from its own ashes, is its own derivative?”
—Francois le Lionnais
Unread 08-05-2013, 23:05
Or you could use Y-cables on two of the PWM outputs to control two speed controllers from each.
Unread 09-05-2013, 15:26
FRC #1721
I have got it, we just added 6 different jags in the program and throw out the robotdrive, thank you
Unread 09-05-2013, 15:29
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
You can and should use the PWM Y-Cables, as mentioned, to provide signal to two jags with one PWM output off the Digital Sidecar.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
