Go to Post Nothing says poor quality like a wrinkle in duct tape. - Matt C [more]
Unread 08-05-2013, 16:47
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Record Robot Actions
Originally Posted by thetimemachine View Post
Because there is theoretically more support for LabVIEW and because its supposed to be "easier" because its visual.....I fail to see the easy part:/ But I don't think we can switch to anything else because I know more [even though its just a little] LabVIEW than Java or C++ or something like that...
Now would be the time to switch if you wanted to try a text based language. A great off season project if you wanted to learn one of the other languages is to reprogram the robot in another language. If you would like, once we finish the code rewrite I can send you all of our robot code so you can see what the code for a robot would look like.
Unread 08-05-2013, 22:37
The first attached image shows one way to record all data from one joystick every 20ms until the Done button is pressed. It then optionally saves it to a file. This code would fit well into periodic tasks.
The second image shows how to read all of the data from file and play it back at the same rate.
You probably don't need all six axes of the joystick, and you may want to record more than one. If that is the case, modify the data that goes into the cluster.
If you want to record the motor values and solenoid/relay values instead, that is an easy alternative and can be output from the Drive Robot function, accumulated, and logged.
If you decide to store sensor values and add control loops to the playback, that is indeed harder, and I'd recommend instead that you put that code into Drive Robot and store the set points.
If you are worried about memory usage, you most likely don't need more than 50 elements per second for no more than 15 seconds, or 750 elements in the array. The full joystick data is 50 bytes per element. Even if you store lots more values, for 1KByte per record, you still haven't used a megabyte, so you shouldn't have any memory issues. If you want to optimize for memory, you can move the file I/O inside the loop to avoid the largish array, scale the values from doubles to smaller values, use timestamps to compress the data, or do all sorts of other fun things.
As for switching to a different language, or practicing the language your team used this year, the off season is a great time to do it. I don't know of anything in command based programming that would make this any easier. Personally, I'd encourage you to become familiar with several of the languages as they each have unique features and values.
Greg McKaskle
ID:	14798  Click image for larger version
Unread 09-05-2013, 08:14
Flywheel Police
Greg McKaskle
I agree completely Greg. No one language is better than another, and it is a great tool to have knowledge of several different languages.
Unread 09-05-2013, 10:30
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
Thank you so much for the pictures that should help a lot!
I will probably look into C++ in the off season..but this and vision processing in LabVIEW will come first... [Our team is also working on making an encyclopedia for everything in FRC so that'll take some time too...]
I'll bring this up to our coach and we'll try it out
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
Unread 09-05-2013, 20:27
Be sure to fix my misspelling in the path.
Greg McKaskle
Unread 09-05-2013, 23:04
MathMaven MathMaven is offline
AKA: Elisha Sword
FRC #3175 (Knight Vision)
MathMaven is on a distinguished road
I couldn't help thinking of The New Cool when I saw the title.
—Elisha Sword
2010–13: FRC Team 3175 (Knight Vision), student, lead programmer
2012–13: FRC Team 3175 (Knight Vision), lead website designer
2014: FRC Team 3175 (Knight Vision), programming mentor
“Who has not been amazed to learn that the function y = e^x, like a phoenix rising from its own ashes, is its own derivative?”
—Francois le Lionnais
