Go to Post It sounds like "whirr" if you do it right, and "clack clack grunge snap @$@%^!!" if you don't. - dtengineering [more]
Unread 09-05-2013, 13:25
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Do You Think We Would Stall?
Originally Posted by RoboTigers1796 View Post
Generally my questions are:
1. Do you feel this drive train will work effectively?
2. We usually use #35 chain so will #25 chain break if we get into low gear and get into a real good pushing match?
3. any general comments or suggestions for improvement (different gear ratio that you've found successful, etc.) will be greatly appreciated.
Thank You! Much appreciation in advance.
1. I don't see why not, our team has used a very similar system for several years with both toughboxes and super shifters and have never had any issues. Just like your plan we direct drive the center wheel with a Hex, with the other wheels being driven off of the center wheel, though instead of using 6wd we use 10wd or 8wd.
2. It's possible. We've bent/broken #35 chain in pushing matches before. Personally, I would recommend sticking with #35 chain for the drive system. I've seen teams use #25, but they seem to be the exception to the rule imo. Keep in mind that #25 chain is only rated to 140 lbs of working load, where as #35 chain is rated to 480 lbs (source).
3. Honestly, the setup your suggesting sounds good. As I suggested above, you might want to stick with the #35 chain if you're worried about getting into pushing matches, but otherwise the plan looks solid to me.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 09-05-2013, 13:45
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
  1. As a whole your idea sounds good. it should work well. One thing that troubles me is the wheel setup. How will you connect the sprockets to the center wheel? Both on the same side? One on each? If you put them on the same size, I can almost guarantee the chains will get on top of one another and get stuck. We lost our entire 2012 season that way. Your best bet would probably be to put them in different sides, which might interfere with the gearbox... But if you plan correctly it would work.
  2. I have no experience with #25 chains, but many teams in Israel use them for drives, and I haven't heard of a chain breaking yet (I've made some research when we thought of moving to #25 chains). They're weaker but will probably hold. If you're not sure, hang one from the ceiling and have a... "big" person hang off it, see if it breaks (with a helmet and safety goggles, just in case).
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 09-05-2013, 13:57
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Regarding #25 chain, use the largest sprockets you reasonably can, and come up with a bulletproof tensioning system. Large sprockets reduce the load passed through the chain, and makes the chain more tolerant to stretch and misalignment. We had a real bad experience running a #25 chain drive with 16t sprockets. The weight and space reduction can be worth it, but you have to be more careful than with #35.
Unread 09-05-2013, 14:10
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
With those ratios, you're going to spend most of your time in high gear (if your driver knows what's good for them...), and use low for getting out of defence or pushing objects. And with that top speed, you won't stall, but you will pull significant current as you depart from a standing stop.
If you can shift fast, you can mitigate this by starting in low, and then transitioning to high quickly—it might be worthwhile to automate this.
Another solution is to add motors—because that spreads the load across more circuit breakers and more motors, for better overall performance. But that would require re-engineering the Super Shifter a little bit. (I've done it before; it's not a huge deal, especially if you're starting now.)
As for the chain, if you engineer it correctly—as Joe described—you can make it work. Understand the relationship between tension in the chain and torque on the shaft, and you'll get a good idea if you're exceeding the manufacturer's specifications. (Remember to consider the case of sudden reversing loads.)
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
I can't speak to the stall question, but #25 chain is sufficient provided you follow a few simple rules:
  1. Make sure you have at least 180 degrees of wrap on each sprocket.
  2. Make sure your sprockets are properly aligned.
  3. Make sure the chain is properly tensioned.
  4. Make sure you buy quality chain - McMaster chain has been good to us. One year we bought less expensive chain from another supplier and had nothing but trouble with it. We will always use McMaster for chain now.
This year we had a high traction robot using #25 chain and had no issues. We've pushed robots sideways across the field. During our entire season, I only remember 3 robots who brought us to a stalemate while trying to push: 25, 68, and 296. There may have been others, but that's all I can recall. The moral of the story is despite doing lots of pushing against teams like these we had no issues with the #25 chain.
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
Unread 09-05-2013, 14:34
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
i'd use 25h instead of regular 25 chain. its pretty much exclusively sold by scooter and gokart venders.
http://www.partsforscooters.com/25H_roller_chain
http://www.amazon.com/Mini-Pocket-Bi...dp/B0059ZPHEU/
25h is rated at 1750lbs while regular 25 is rated at 875lbs. 35 is rated at 2100lbs.
My Instructables
Unread 09-05-2013, 14:36
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
Thank you all for the great input and suggestions. They are truly valued.
Tristan, we were definitely going with the pneumatic shifting option so I think that would be an Exciting project for the programming team.
As to bards concerns here is my super detailed cad model I just made . Sorry if I slow some of your computers down trying to view it.
Orange = dead axle
Red=live hex
Green =chain runs to wheels
Everything else should hopefully be self explanatory with the above description of the system.
Tensioners would be added where needed.
2014 Attended: NYC Regional, SBPLI Regional NYC Regional- Imagery Award in honor of Jack Kamen
2013 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- Gracious Professionalism Award sponsored by Johnson & Johnson,SBPLI Regional- #4 Alliance Captain & Regional Winner- With our impeccable alliance 358 and 3171
2012 Attended: NYC Regional, SBPLI Regional, FIRST Championships NYC Regional- #7 Ranked Seed & Semi-Finalists, SBPLI Regional- #3 Seed & Regional Winner- With our very awesome alliance 527 and 870, Industrial Design Award sponsored by General Motors
2011 Attended: NYC Regional, SBPLI Regional SPBLI Regional- Xerox Creativity Award and #5 Alliance Captain
2009 Attended: NYC Regional, FIRST Championships NYC Regional Winner- With our amazing alliance 1807 and 56
Unread 09-05-2013, 14:42
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Do not gear low gear that slowly, you will regret it.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 09-05-2013, 16:20
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
That spread between gears seems bit too large, you want to keep it around 2-3 X spread for optimal all around usage. Your at a 4 X spread
2016: FRC 865 Mentor
Unread 09-05-2013, 16:40
cbale2000's Avatar
AKA: Chris Bale
*picture*
Looks good to me. Though ideally if you plan your wheel spacing correctly you shouldn't need chain tensioners.
That depends on the application, really. In 2007 we played as a primarily defensive robot and had a similarly low gear. We were able to simultaneously push 3 robots sideways on several occasions. For this years game, however, I would agree it's probably a bit excessive, but again, depends on what you need it for.
Unread 10-05-2013, 12:55
FRC #1836 (MilkenKnights)
I would bet that your low gear was traction limited, so you could have geared higher without losing pushing force.
Unread 10-05-2013, 13:30
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
I think their gearing is fine. Assuming a traction coefficient of 1.3 the current draw would just under 120 amps total with their gearing. This would give them plenty of safety factor just in case they ended up on the heavy side and having current drawn from another mechanism. I think for teams that are trying shifters for the first time, its better to start on the slow side. Having a extra traction limited low gear will give them one less thing to worry about.
I would recommend using the 22 tooth sprockets at least with that much torque if you want to try #25 chain.
This is very close to 987's gearing according the behind the bumper video from FRCtop25.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
