Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 09-05-2013, 13:57
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Do You Think We Would Stall?
Regarding #25 chain, use the largest sprockets you reasonably can, and come up with a bulletproof tensioning system. Large sprockets reduce the load passed through the chain, and makes the chain more tolerant to stretch and misalignment. We had a real bad experience running a #25 chain drive with 16t sprockets. The weight and space reduction can be worth it, but you have to be more careful than with #35.
Unread 09-05-2013, 14:10
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
With those ratios, you're going to spend most of your time in high gear (if your driver knows what's good for them...), and use low for getting out of defence or pushing objects. And with that top speed, you won't stall, but you will pull significant current as you depart from a standing stop.
If you can shift fast, you can mitigate this by starting in low, and then transitioning to high quickly—it might be worthwhile to automate this.
Another solution is to add motors—because that spreads the load across more circuit breakers and more motors, for better overall performance. But that would require re-engineering the Super Shifter a little bit. (I've done it before; it's not a huge deal, especially if you're starting now.)
As for the chain, if you engineer it correctly—as Joe described—you can make it work. Understand the relationship between tension in the chain and torque on the shaft, and you'll get a good idea if you're exceeding the manufacturer's specifications. (Remember to consider the case of sudden reversing loads.)
