Re: Do You Think We Would Stall?
I can't speak to the stall question, but #25 chain is sufficient provided you follow a few simple rules:
This year we had a high traction robot using #25 chain and had no issues. We've pushed robots sideways across the field. During our entire season, I only remember 3 robots who brought us to a stalemate while trying to push: 25, 68, and 296. There may have been others, but that's all I can recall. The moral of the story is despite doing lots of pushing against teams like these we had no issues with the #25 chain. |
i'd use 25h instead of regular 25 chain. its pretty much exclusively sold by scooter and gokart venders.
http://www.partsforscooters.com/25H_roller_chain http://www.amazon.com/Mini-Pocket-Bi...dp/B0059ZPHEU/ 25h is rated at 1750lbs while regular 25 is rated at 875lbs. 35 is rated at 2100lbs. |
Thank you all for the great input and suggestions. They are truly valued.
Tristan, we were definitely going with the pneumatic shifting option so I think that would be an Exciting project for the programming team. As to bards concerns here is my super detailed cad model I just made . Sorry if I slow some of your computers down trying to view it. Orange = dead axle Red=live hex Green =chain runs to wheels Everything else should hopefully be self explanatory with the above description of the system. Tensioners would be added where needed. ![]() |
Do not gear low gear that slowly, you will regret it.
That spread between gears seems bit too large, you want to keep it around 2-3 X spread for optimal all around usage. Your at a 4 X spread
That depends on the application, really. In 2007 we played as a primarily defensive robot and had a similarly low gear. We were able to simultaneously push 3 robots sideways on several occasions. For this years game, however, I would agree it's probably a bit excessive, but again, depends on what you need it for. Last edited by cbale2000 : 09-05-2013 at 16:43. |
#7
I would recommend using the 22 tooth sprockets at least with that much torque if you want to try #25 chain. This is very close to 987's gearing according the behind the bumper video from FRCtop25. |
