6 Wheel Tank Drive
Is it possible to program 6 sims on 6 different jags with tank drive? i tired programming it with the frc c++ simple template but it wont let me add 6 jags only 4 any help?
Re: 6 Wheel Tank Drive
You could also make your own class that inherits from robotdrive but accepts 6 speed controllers in it's constructor and handles them properly. |
Alternatively, you can just brute-force your way through and code each Jaguar manually. It's ugly, but gets the job done.
Or you could use Y-cables on two of the PWM outputs to control two speed controllers from each.
I have got it, we just added 6 different jags in the program and throw out the robotdrive, thank you
You can and should use the PWM Y-Cables, as mentioned, to provide signal to two jags with one PWM output off the Digital Sidecar.
