| My motors are hot for you! |
Do You Think We Would Stall?
So I am requesting the opinions of fellow CD'ers. I've done a lot of searching on CD to get ideas.
Christmas has come early for us and we have two shiny new supershifters sitting in front of us (ordered a week before the new shifting gearbox was announced by AM ) But I digress...We have always done a simple dropped 6wd (4 plactions/2 omnis) 4CIM toughbox set-up, each year gearing to try to go just a little faster. This year we feel we have reached our limit on top speed and a combination of bad calculations and poor wiring connections caused us to have drivetrain trouble for the first year in 5 years. So I want to employ the help of CD to see if you think our setup will ideally work with our new SShifters. Yes, this will be an off season project, and will be prototyped a few times but I want to at least make sure we are building something plausible as there are so many experienced drive train builders here and we are inexperienced in exploring outside of our regular set-up. Essentially our idea is a 4 CIM, 6wd center dropped 1/8". Wheels would be 4" performance wheels with blue nitrile treading. For the prototype we were going to direct drive the center performance wheels with a hex shaft straight off the SS (not cantilevered). The other 2 wheels would be driven off the center wheel with #25 32:32 tooth sprockets. The gearing on the supershifter would be the 4:1 overall option (low- 24:1, high 6:1) This gives us a theoretical 15.45 ft/s in high, and 3.86 ft/s in low. I am however, worried with stalling problems; so to my untrained eyes it appears to have the potential to work well, but I'd like a more experienced opinion though. Generally my questions are: 1. Do you feel this drive train will work effectively? 2. We usually use #35 chain so will #25 chain break if we get into low gear and get into a real good pushing match? 3. any general comments or suggestions for improvement (different gear ratio that you've found successful, etc.) will be greatly appreciated. Thank You! Much appreciation in advance. |
Re: Do You Think We Would Stall?
2. It's possible. We've bent/broken #35 chain in pushing matches before. Personally, I would recommend sticking with #35 chain for the drive system. I've seen teams use #25, but they seem to be the exception to the rule imo. Keep in mind that #25 chain is only rated to 140 lbs of working load, where as #35 chain is rated to 480 lbs (source). 3. Honestly, the setup your suggesting sounds good. As I suggested above, you might want to stick with the #35 chain if you're worried about getting into pushing matches, but otherwise the plan looks solid to me. Last edited by cbale2000 : 09-05-2013 at 13:29. |
Regarding #25 chain, use the largest sprockets you reasonably can, and come up with a bulletproof tensioning system. Large sprockets reduce the load passed through the chain, and makes the chain more tolerant to stretch and misalignment. We had a real bad experience running a #25 chain drive with 16t sprockets. The weight and space reduction can be worth it, but you have to be more careful than with #35.
With those ratios, you're going to spend most of your time in high gear (if your driver knows what's good for them...), and use low for getting out of defence or pushing objects. And with that top speed, you won't stall, but you will pull significant current as you depart from a standing stop.
If you can shift fast, you can mitigate this by starting in low, and then transitioning to high quickly—it might be worthwhile to automate this. Another solution is to add motors—because that spreads the load across more circuit breakers and more motors, for better overall performance. But that would require re-engineering the Super Shifter a little bit. (I've done it before; it's not a huge deal, especially if you're starting now.) As for the chain, if you engineer it correctly—as Joe described—you can make it work. Understand the relationship between tension in the chain and torque on the shaft, and you'll get a good idea if you're exceeding the manufacturer's specifications. (Remember to consider the case of sudden reversing loads.) |
I can't speak to the stall question, but #25 chain is sufficient provided you follow a few simple rules:
This year we had a high traction robot using #25 chain and had no issues. We've pushed robots sideways across the field. During our entire season, I only remember 3 robots who brought us to a stalemate while trying to push: 25, 68, and 296. There may have been others, but that's all I can recall. The moral of the story is despite doing lots of pushing against teams like these we had no issues with the #25 chain. |
#7
i'd use 25h instead of regular 25 chain. its pretty much exclusively sold by scooter and gokart venders.
http://www.partsforscooters.com/25H_roller_chain http://www.amazon.com/Mini-Pocket-Bi...dp/B0059ZPHEU/ 25h is rated at 1750lbs while regular 25 is rated at 875lbs. 35 is rated at 2100lbs. |
#8
Thank you all for the great input and suggestions. They are truly valued.
Tristan, we were definitely going with the pneumatic shifting option so I think that would be an Exciting project for the programming team. As to bards concerns here is my super detailed cad model I just made . Sorry if I slow some of your computers down trying to view it. Orange = dead axle Red=live hex Green =chain runs to wheels Everything else should hopefully be self explanatory with the above description of the system. Tensioners would be added where needed. ![]() |
#9
Do not gear low gear that slowly, you will regret it.
#10
That spread between gears seems bit too large, you want to keep it around 2-3 X spread for optimal all around usage. Your at a 4 X spread
#11
That depends on the application, really. In 2007 we played as a primarily defensive robot and had a similarly low gear. We were able to simultaneously push 3 robots sideways on several occasions. For this years game, however, I would agree it's probably a bit excessive, but again, depends on what you need it for. Last edited by cbale2000 : 09-05-2013 at 16:43. |
#12
I would recommend using the 22 tooth sprockets at least with that much torque if you want to try #25 chain. This is very close to 987's gearing according the behind the bumper video from FRCtop25. |
