Go to Post it should not matter the gender of a person but rather their ability. - vivek16 [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 09-05-2013, 16:54
jacob9706 jacob9706 is offline
AKA: Jacob Ebey
FRC #3574 (High Tekerz)
jacob9706 is on a distinguished road
Re: Subsystem / Command style code
Originally Posted by Jon Stratis View Post
It was set up as a command group with a number of commands set up sequentially (you can have sequential and parallel commands) - the idea being that to climb we wanted the arm to go to position 1, then position 2, then position 3, etc. Doing this with the command group and sequential commands utilizing a PID loop was pretty easy - each command would call the PID controller until we hit the target point, then return true (in fact, we only really had 1 command that was passed in different target values).
Now, for the hard part... how do we reset the command group in the middle (either between commands, or in the middle of a command)? As we looked at it, it quickly grew extremely messy to get the type of interrupted behavior we wanted - the option to restart completely, or simply "back up" one or more commands. This was driven mostly by a couple of runs where the climb got messed up and we missed the next bar. We ended up solving that issue a different way, but it still would have been real nice to have a "back up one step" ability in the command group.
We ended up having an issue with how things were scheduled, when they execute and what happened once they were finished. We implemented our own CommandGroupBase. https://github.com/Team3574/Alastair...roup2Base.java. I hope it helps some other teams that want to continue to dabble in the command / subsystem style code.
This shows an implementation of a drive with my proposed system. There is a DriveTeleop method that drives with joysticks and a DriveForTime that is scheduled here. I believe this (for me atleast) is a much more readable and easier to maintain system than the current command base used in java.
* Team 3574 Alumni
* 2011 - Highest Seeded Rookie
* 2011 - Rookie All-Star
* 2012 - Engineering Inspiration
* 2012 - Olympic Deans List Winner
* 2013 - Engineering Inspiration
* 2013 - Judges Award (For unique circular robot and the way the team works together.)
