Re: An improvement to OPR
P = (A^-1) * S where P is the OPR, A is the binary matrix denoting teams in each alliance and S is the alliance scores, then Frenchie461 is essentially advocating Pt + Pa*i = (A^-1) * (St + Sa*i) and since matrix multiplication is distributive Pt + Pa*i = (A^-1) * St + ((A^-1) * Sa)*i So you'll end up with the same result as calculating each OPR component independently. You'll get least-squares best fit for each component (as you would otherwise), but there won't be any additional interaction gained between them. This makes sense, because the least-squares fitting part of the operation happens when taking the inverse of A, and isn't affected by the value of S (whether real or complex) that it is post-multiplied by. Performance-wise, I would guess they would take about the same amount of time, assuming you're not re-calculating the value of A^-1 when doing the calculations independently. note: the inverse operation written ^-1 above becomes the generalized inverse for non-square cases of A |
I'm not sure how this is an improvement; your code might be more concise but only if you're working with a computational package like MATLAB.
It's only an improvement so far as it's more data than most teams usually compute, and it should be computationally faster than a pair of OPR calculations. Hypothetically, let's say that OPR is a O(N^3) operation, with this method it's N^3 to find auton and teleop rather than 2(N^3).
In the formula for OPR, namely [A][OPR]~[SCORE], [OPR] and [SCORE] need not be vectors - they can be matrices. So instead of [OPR] being a Nx1 column vector, it can be an Nx2 matrix... and [SCORE] can be a (2M)x2 matrix. The first column of [OPR] and [SCORE] can then be for TeleOp, and the second column for Autonomous. This can be extended to any desired number of columns. For example use 4 columns for TeleOp, Autonomous, Climb, and Foul points. Adding extra columns to [OPR] and [SCORE] increases the computation time only minimally, since the lion's share of the computation is spent factoring [A]T[A]. Last edited by Ether : 10-05-2013 at 10:13. |
)Other than that, it's a cool idea and would be a fun way to team the concept to new students around that level. In terms of data though, I don't know that it brings something new. It'd actually complicate my work to do it that way, because the matrix case Ether describes allows the simultaneous calculation of endgame OPR by the same method (i.e. it's not limited to 2, and we're looking for at least 3 basically ever year). |
http://www.chiefdelphi.com/forums/sh...t=twitter+data It has everything you need. Last edited by AGPapa : 10-05-2013 at 11:32. Reason: spelling |
#7
http://www.chiefdelphi.com/forums/sh...53&postcount=1 As with any analysis using Twitter data, caveat utilitor. |
#8
[/and now back to your regularly scheduled thread] |
