Go to Post what is FIRST?...It's about innovation, hard work, inspiration, teaching, learning, experiment, strategy, competition, meeting new people, being inspired, aiming high and changing paradigms...Really, FIRST is what you make of it. - jarowe [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 01-05-2013, 21:25
depth_Finder's Avatar
depth_Finder depth_Finder is offline
I am the one who graphs
AKA: Quinn Schiller
FRC #1983 (Skunk Works)
Team Role: Tactician
depth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to beholddepth_Finder is a splendid one to behold
Re: Paper Scouting Sheets
Are the Q1-Q12 parts on the side of the sheet time slots?
Check out my tutorials at http://www.tableausoftware.com/first-robotics
Unread 01-05-2013, 22:34
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Not sure whose you're talking about, but they sound like qual matches. 12 is about the max per event.
Unread 01-05-2013, 22:37
AKA: Quinn Schiller
Thanks. For some reason I thought it was different time periods for each game.
Unread 01-05-2013, 23:16
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
That seems much cheeper than using dividers. They take so long to file sheets and are expensive.
We use something like this.
And these are the folders though we can find them cheaper at Walmart.
It's sort of annoying to need a new set for each regional but I guess we could keep them all and just have one per team forever. Then we could reuse from year to year.
I learned this method from doing Inspections at different event. When you remove a sheet from it's folder turn the folder sideways so you know which ones are currently out of the box. If you label both the top and side of each folder it's very fast to get them in and out between matches.
Unread 01-05-2013, 23:36
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
340 has found that these sheets are extremely helpful. These are printed on 11x17 inch paper, and you just use tallies to mark what a team has done in their match. They're great at showing trends (whether a team has improved, or gotten worse), and they are easy to read and understand- and they'll never give you the blue screen of death! Maybe Justin can show you what a filled out one looks like (he's got 340's framed in his room from last year ).
Unread 02-05-2013, 20:30
robobuilder robobuilder is offline
FRC #2037
robobuilder is an unknown quantity at this point
We use one sheet per team with a row for each match and a column for each part of the match (ie auto, shooting, climb, etc) this makes it easy to look down the list and see how consistant their robot is, however i've heard larger teams often use individual sheets for each team each match because it means more people can scout resulting in more accurate data.
Unread 02-05-2013, 20:32
AKA: Quinn Schiller
Thank you everyone for sending me these sheets. I will be sure to use them and credit them to their appropriate creators.
Are there any other "Best Practices" I should be sure to include in this workshop?
Unread 02-05-2013, 22:38
lefkoc lefkoc is offline
FRC #0195
lefkoc is an unknown quantity at this point
I would recommend, if you are going to show them paper scout sheets, to make sure they are aware that they need to keep them organized using something like a binder, which I use, or an accordian folder, which team 20 used. We have had great luck the last two years at CT partly due to strategy, and our scouting systems have really helped. Also, I'm not sure exactly what you are planning to cover or how in depth, but you might want to touch on backscouting and pit scouting too. I know I do a lot of work, along with the rest of my team, but it has been paying off for us... Oh, and I can't see the sheets that other teams are using, but for the most accurate data, especially pit scouting, warn them to stay away from opinion questions. Then the data quality can vary from person to person. And have them make sure that they are very organized, like schedules and time slots for scouting, because I know I have run in to problems having not enough scouts, and my team has 40+ members. Having the same people doing it the whole time can be exhausting... I know that was a lot, but that's my main job on my team so...
Just my take!
Special note - with binders, if you get plastic separators you can use stick on tabs and then just reuse them each competition. Easy way for them to save money if they want to.
Unread 03-05-2013, 00:08
hiyou102's Avatar
hiyou102 hiyou102 is offline
hiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud ofhiyou102 has much to be proud of
2056 released their scouting sheet during a webinar earlier this year. It can be found here.
Team 4334 2012-2014
Unread 09-05-2013, 23:57
FRC #2037
Originally Posted by AllenGregoryIV View Post
We hold it all in a hanging file folder with individual folders for each team(it's like $5 for a hundred of them). There is normally only one sheet per team in each folder but sometimes we will have notes or the little descriptions teams give out about their robots in with the scouting sheets.
I saw someone walking around with one of these... and was so jealous.
[IMG] code is Off
