Go to Post Thinking about this game within the confines of previous years will limit you. - Gregor [more]
Unread 09-05-2013, 01:02
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Re: 233 telescoping arms how do they work?
Originally Posted by coalhot View Post
From one of the post photos threads. Look at 254's set, there are a few really good shots of the arm, and the bearing assemblies it rides on.
That exposed bearing assembly pictured in the referenced photos is for the simple level 1 hanger (hook on the end of a piston), which is entirely separate from the 233 climber arms. I am pretty sure that the 233 climber arms use bearings for only the front-back sides and use plastic on the other two sides.
-Travis
Unread 09-05-2013, 01:46
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Links that helped me solve this problem:
Take a long stare at a few of these and you will figure out how they work.
https://www.dropbox.com/sh/3fxabc28nvvkcr8/A2tQie9tgK
specifically: https://www.dropbox.com/sh/3fxabc28n...f:DSC_0149.JPG
Also: http://www.chiefdelphi.com/forums/sh...ng+a+clim ber
Good luck!
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 09-05-2013, 09:01
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
233's 2011 Arm was a beauty to behold. Good luck to anyone who wants to make one
ID:	14804  Click image for larger version
GitHub
Unread 09-05-2013, 10:11
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Can we please get a CAD model of those? Or extremely detailed pictures? It's so hard to see what is going on in there
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 09-05-2013, 11:13
Doug G's Avatar
Doug G Doug G is online now
Coach / Teacher
FRC #0701 (Robovikes)
Why is that when I look at 254's machine to see how they did something, I come away with more questions than answers... that machine and its mechanisms are so condensed, it's just insane.
Unread 09-05-2013, 16:00
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
I can only speak for the 233 arm on this topic. First off, a gearbox is attatched to the outside of the largest box (4d0 x 4d0 x d125 al box) at the bottom of the tower. It has a shaft that transfers power to a sprocket on the inside of the box. At the top of the box is an idler sprocket which is also the tensioner for this chain. We will call this chain 1. Chain 1 is attatched to the outside of the next box (2d5 x 2d5 x d125 al box) thru what I call the "chain anchor". The motor/gearbox drives this stage in and out directly.
The gearbox has a 10 turn pot attatched which controls the limits and also the PID control for ramping up and down the power as the tower nears its limits at each end of its travel. Now here is where it gets a little tricky, the opposite side if the 2d5 box has a shaft in the bottom with a sporcket on the inside and the outside, this is what drives the final stage of the tower. It also has an idler at the top which also acts as the tensioner for these 2 chains.
The chains both have a "chain anchor". The chain on the inside of 2d5 box is attached to the bottom of the final stage (1d0 x 1d0 x d125 al box). The chain on the outside of the box is attatched to the inside of the 4do box. The key is that the anchors are on opposite sides of the chain, this allows the second stage to use the anchor to drive the chain which extends the final stage at the same time. This is a very lengthy post and I may not of explained the subject completely but it has started an open line of communication. Ask any questions you may have and i can explain why Charlie did not like the delrin bearing blocks from 2k10.
Mike D "233 for life"
See Ya
Unread 09-05-2013, 16:36
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
Awesome stuff. Thanks for all the info about these mechanisms.
When we've built these cascaded telescoping lifts/arms in the past, we've used a winch system for the first stage. What I'm having trouble wrapping my mind around with both of 233's and 254's telescoping arms is where the extra chain/timing belt, goes when these mechanisms are extended. Or are just the cascaded sections using the timing belt/chain?
Always trying to come up with better solutions, and these are the type of mechanisms we're all striving to make (in some small way).
Unread 09-05-2013, 17:43
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
In this year's arms, the other end of the belt comes off the bottom pulley and then goes back up inside the bottom of 1x1 tube (the last stage), where it is clamped.
This section of belt (from the pulley to the bottom of the last stage) is what takes all the tension when the arm is being retracted. This way, the force exerted by the weight of the robot while climbing is just transmitted through the (large) bearings and shaft supporting the bottom pulley, and not on any of the tiny ones where the belt doubles back on itself.
The beauty of using a telescoping arm for hanging, in my opinion, is that there are no moments exerted on any of the stages during retraction.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 09-05-2013, 18:41
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
If I'm reading this thread right, the arms are basically a condensed version of this right?
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 09-05-2013, 19:05
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
That's similar to 254's arm, in that it is a multi-stage, continuous lift.
If I understand MikeD's post correctly, 233's multi-stage arms are essentially cascaded lifts, but the second stage does not return to the original power source (and is instead driven "passively" by a sprocket that is turned as the first stage extends).
The key difference for both arms is that all the stages are nested within each other, which presents numerous challenges and advantages.
Unread 09-05-2013, 19:54
CENTURION's Avatar
Ah, okay, yeah we used a cascade like the 233 one you describe in 2011 to raise/lower tubes.
Yeah, the nesting sounds very hard to do. Maybe if I get bored over the summer I'll CAD up something
Unread 09-05-2013, 21:05
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The nesting is only really difficult if you want to put it into a very small package. Pink's arm and Poof's variation show true engineering elegance in packaging, from the wide rollers to the usage of belt (low profile) to the threading of the linear springs through the system.
The question that you'll also have to answer is the orientation of the constant force springs. Do you use them to extend the arm and only pull one way with your motors? Do you use to retract the arm so they help you lift the robot, but power the arm in both directions?
It's a really awesome design that I wanted to understand to put it in our 'toolbox'.
Unread 10-05-2013, 04:14
FRC #1836 (MilkenKnights)
If somebody is still having a hard time understanding how the poof's arm works, I took many pictures which are posted here: https://drive.google.com/folderview?...&usp=sha ring
Unread 10-05-2013, 09:34
all hail Passmore
In our application we use the constant force springs to assist the extend function only. It offsets the weight of the manipulator on the end of the tower/elevator. The motor/motors have plenty of power for lifting the robot and we use a locking type ratchet to hold the weight up after the buzzer but the idea of having the motor/motors stalled out to hold position while the tower is extended is not, in my opinion, a healthy one. This year we did an elevator and used constant force springs to assist the elevator in lifting our shooter deck, it weighed in at about 18lbs. I find it ironic that we did an elevator and the Poofs did telescoping towers this year
See Ya
Unread 10-05-2013, 09:43
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
To the people who have posted in this thread: I just want you to know that after the school year ends, I'm going to devour the information in this thread, including both the pictures and written explanations. I am looking forward to trying to figure out the guts of one of these arms and working with some students to create a model of something we could build. Thanks very much for all of the posts.
